Old 08-18-2020, 08:05 PM #1
NJ-4Runner NJ-4Runner is offline
NJ-4Runner will become famous soon enough
New Front shock top mount bolts not lining up
I thought I was going crazy but the new upper shock mount I bought for my new bilstein setup does not match the stock part. The studs on the mount are spaced a little farther apart and it won’t mount into the truck. I am pretty sure it is made by Gabriel, made in China. I even went to autozone to check against another brand but all they had there was the same brand. It is not off by much but it won’t make it into the 3 holes in the upper shock mount. Has this happened to anybody else?
NJ-4Runner is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 08:50 PM #2
spartacus's Avatar
spartacus's Avatar
you can use your old tops just use a newer insulator piece and call it a day. That's what I've done'in the past.
Old 08-18-2020, 08:58 PM #3
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
Go to NAPA and buy a new top that fits and just change them out. Keep in mind the Tundra tops wont fit, I had that same problem.
ArmArak is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 09:32 PM #4
I would but the old tops are in super bad shape...totally rusted.
Do you know what brand the ones you got from NAPA were?
Old 08-18-2020, 09:41 PM #5
spartacus's Avatar
spartacus's Avatar
I know kyb strut mounts fit well .Amazon.com: KYB SM5184 - Strut mount: Automotive
Old 08-18-2020, 09:48 PM #6
Thanks!! Just clicked that link and bought them. Some of that money should go to you for making it so easy!
Old 08-19-2020, 01:27 AM #7
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Maybe you bought Tundra top plates? Pretty sure they are slightly different by the bolt pattern.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 09:28 AM #8
Good call. The ones I ordered from Rockauto were Gabriel part # 143325. This is the same part number/part that I checked out at autozone.
If you click the part number on the Rockauto site it lists the 4runnner, sequoia, tacoma, and tundra as compatible vehicles. I guess that's the issue right there.
When I look under KYB SM5184 it only lists the 1996-2002 4Runner so most likely that one will fit correctly. KYB also lists a different part number, SM5442 for the Tundra.
Lesson learned. I should have done a little bit of cross reference research before I pulled the trigger on that particular mount. Hopefully someone else comes across thread if they have the same problem. I was installing the shocks using the on-vehicle compression method and I was fitting the top plates to the truck when I found this. If I would have taken the shocks and springs somewhere to have the assembly put together before I installed it I would have flipped out when the tops wouldn't go in!
brand , made , mount , shock , upper
New Toyota Upper Front Shock Tower Mount Kit by Low Range Off Road (TSP-UST) cougarzluv For Sale: T4R Items 0 06-04-2016 09:21 PM
Rear shock bolts are a M*@#%#^%$#ker maxspeed96ct 3rd gen T4Rs 36 03-18-2015 11:07 PM
Tire Rub On Front Fender Lining WaySlowWhitey 5th gen T4Rs 11 04-29-2012 10:53 PM
