Old 08-19-2020, 07:50 PM #1
nathanroyse nathanroyse is offline
nathanroyse is on a distinguished road
Should i drain and fill?
I bought this 4Runner about 2 weeks about and it has started to have hard shifts. It still shifts into every gear but i would rather try and fix it now before something worse happens when im away from home. Ive heard that flushing the transmission when its never been done before can also make problems worse. There are no records of anyone servicing the transmission. The car is at 191k miles. Here are some pictures of the condition of the fluid and the pan. Please let me know what you guys think and/or what youve done if youve had this problem. Thank you!
Should i drain and fill?-image0-jpeg  Should i drain and fill?-image1-jpeg
nathanroyse is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 08:00 PM #2
itskohler's Avatar
itskohler itskohler is offline
itskohler is on a distinguished road
itskohler's Avatar
If you got with a flush make sure the place uses whats known at a T-Tech machine. It used the transmissions own pump to move the fluid. I've never bought into the idea that flushing a transmission will harm it, specially using a T-Tech. If a flush does kill your transmission, it was on its way out anyways.
98 Limited - 2010 Triumph Daytona - 2017 GTI
itskohler is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 08:02 PM #3
I havent heard of that but ill check it out. ive been told that if you remove the old fluid with all the particles in it and replace it with new fluid, it wont have the particles which might make it start to slip. thats a bad explanation but hopefully it makes sense.
Old 08-19-2020, 08:03 PM #4
lockedlex's Avatar
lockedlex lockedlex is offline
lockedlex will become famous soon enough
lockedlex's Avatar
Also, make sure your transmission kickdown cable is properly adjusted if you're a 96-00. If it's set too tightly, you will get harsher downshifts.
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
lockedlex is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 08:05 PM #5
Ill look into it. How do i adjust it? its not so much downshifts though. its when im accelerating.
Old 08-19-2020, 08:09 PM #6
maxthebird maxthebird is offline
maxthebird is on a distinguished road
Your transmission fluid does not look that bad. It's a pink color when new and yours looks slightly off but OK. A bad color would be a dark brown which indicates overheating. You can try just changing the fluid without a flush and see what happens. A power flush is an iffy proposition if there is a lot of wear and clutch material in the pan.
maxthebird is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 08:12 PM #7
lockedlex's Avatar
lockedlex's Avatar
yes, it basically makes all shifting (up/down) harsher vs. gentler (slipping softly, which isn't good either). Generally, you actually want a crisp/harsher shift to preserve transmission life.
It's called something else officially, but commonly referred to here as a kickdown cable. I'd run a search for the adjustment.
Old 08-19-2020, 08:19 PM #8
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
^^^ I second this. Sometimes rough shifting is just the sign of old fluid. As said, if a flush hurts your trans, then something was seriously wrong already. I understand this is a common myth, but it makes no logical sense that fresh, new fluid will hurt your car over of worn down fluid that's thinned out and possibly carrying particulate. I was about to go for a flush soon too, since after cold starts it's a little sticky between 2nd and 3rd for the first 1-2 shifts (plus I don't think it's ever been changed or had a new screen put in)
What WILL hurt your car is someone doing a flush improperly, so make sure they know what they're doing
Old 08-19-2020, 08:22 PM #9
itskohler's Avatar
itskohler's Avatar
Any particles that are large enough to keep the transmission alive are being filtered by the pan filter anyways. Which only furthers what I've always found to make sense, if a transmission flush is what does it in, it was already a dead transmission running on borrowed time.
Now, a powered flush is different from a T-Tech. The trans fluid doesn't flow backwards, isn't propelled faster than it should be. Those can wreck an otherwise good trans by clogging ports and pushing particles where they shouldn't go.
Old 08-19-2020, 10:32 PM #10
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
A few thoughts:
Your transmission fluid looks ok. Switching to a quality synthetic fluid like Redline or Royal Purple will smooth the shifts out, that's exactly what it did to mine. Cold starts shift hard though. When we say cold starts, it doesn't have to be cold outside, just any temperature lower than the operating temperature. Once it warms up it should shift smoother.
Your transmission cable is this one:
You want no slack in the cable between the bracket and the throttle body. Same goes with the cruise control. The throttle cable should have just the slightest amount of slack so that the pedal doesn't get stuck open in hot/cold conditions.
326WHP 347TQ
Old 08-19-2020, 10:41 PM #11
TimGFL TimGFL is offline
TimGFL is on a distinguished road
Nice tip! My shift is a little off so I may check that!
TimGFL is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 10:44 PM #12
Originally Posted by gamefreakgc View Post
A few thoughts:
That's a good thought. Mine won't shift into 3rd at all until the temp gauge starts creeping up past the low temp line. Been that way since I bought it 3 years ago.
Old 08-20-2020, 01:15 AM #13
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
If your pan has never been pulled as far as you know it would be best to pull the pan inspect for large chunks and or a bunch of metal it would be good to know. Then wash the pan clean including the magnets don't for get to put them pack in. Replace or wash the trans filter ( OEM has a metal screen that you can see so if it's clean than I would reuse it and save it 30 dollars.) Replace the pan refill the pan see Tim's video on doing this it's perfect. The method he uses is drain and refill from the trans cooler line. Be sure to get a inch lb torque wrench then putting things back. Be sure to check the cable adjustment.
plcfcng is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 04:24 AM #14
Make sure the lever on the trans is operating freely. That lever is in the worse environment.
It’s the throttle valve cable and it controls line pressure.
Your trans may have had a shift kit installed which firms up the shifts. Especially during acceleration when you’re above 1/2 throttle.
I like shifts firm enough that the tires chirp on the 1-2 up shift at WOT.
All three of my 4Runners with anywhere from 120k miles to 280k miles won’t shift into 3rd with a cold trans unless your going above 40mph.
Old 08-20-2020, 11:59 AM #15
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Actually when it's cold it will shift into 3rd.
It's O/D that it won't shift into before it warms up enough.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
records , servicing , shifts , transmission , worse
Need help! Transmission Drain & Fill Samm25 4th Gen T4Rs 1 04-29-2019 11:05 AM
Coolant drain and fill. Block drain plugs. lj4r 4th Gen T4Rs 2 11-24-2018 07:11 PM
ATF Drain and Fill, 5th Gen leje0306 Maintenance/Detailing 0 10-02-2013 08:13 AM
Transmission Drain and Fill 04 V-6 Boaz Maintenance/Detailing 25 08-08-2013 11:11 PM
Doh! '03 V6 4x4 drain and fill quadzillabill 4th Gen T4Rs 5 05-11-2008 07:24 AM
