Old 08-24-2020, 04:16 PM #31
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I haven't had issues with any fans in 30 years of Toyotas. I am sure the climate has alot to do with that western PA dosent get super hot. The OEM fans always worked great for me. Other areas of the world maybe a different story. I suspect issues in hotter climates especially if the fan clutch fails.
Old 08-24-2020, 08:30 PM #32
billyblunk3 billyblunk3 is offline
billyblunk3 is on a distinguished road
Old thermostat....
billyblunk3 is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 09:04 PM #33
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
The jiggle valve (small little metal tab in a hole) is at 12 o'clock in that photo. Turn it 180 degrees so it's at the bottom.
326WHP 347TQ
Old 08-24-2020, 09:06 PM #34
Installed the new thermostat from Toyota with it at the bottom. New coolant from Toyota and a new lower radiator hose.
Old 08-24-2020, 09:36 PM #35
Idle after parts replaced
Cruising without a/c
With a/c on full blast
Old 08-24-2020, 11:22 PM #36
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
That old one didn't look like a OEM one and the jiggle valve was in the wrong spot. Crazy how big of difference the direction of the jiggle valve can make.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 11:28 AM #37
T4topher's Avatar
T4topher T4topher is offline
T4topher is a name known to all T4topher is a name known to all T4topher is a name known to all T4topher is a name known to all T4topher is a name known to all T4topher is a name known to all
T4topher's Avatar
Originally Posted by raKnizek View Post
Removing the electric flex-a-lite fan the previous owner put in and returning my system to stock was the best decision I made.
It adds to the reliability and simplicity of a 3rd gen where I felt the electric fans took away from that in a very critical area.
The fan blades on those electric systems are so thin. I shattered one going through some mildly deep water and it slashed open my radiator. Wouldn’t haven’t happened with the stock fan.
This actually happened to my buddy with the stock fan on our last wheeling trip and I had to drive 45 minutes to get him a new radiator at the closest parts store.. luckily they had one radiator in stock.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 12:39 PM #38
Real Name: Jerod
Real Name: Jerod
A few people put e-fans in just because of this issue. An e-fan you can cut power to if a switch is wired in. You can't turn off the mechanical fan.
326WHP 347TQ
Old 08-25-2020, 01:34 PM #39
T4topher's Avatar
T4topher's Avatar
Yea that’s definitely a nice feature for the electric fans. I always wondered about this fan Flex Fan - 5VZ Flex Fan w/Billet Spacer Kit
I think the bad thing about this fan is it gets rid of the fan clutch..
Old 08-25-2020, 05:46 PM #40
It’s 106 outside and I’m on the freeway at 77mph. Rig is at 207 with the A/C off. Hmmm
Old 08-25-2020, 05:47 PM #41
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
Excellent point. Just make sure you turn it back on as soon as you're out of the water.
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 07:46 PM #42
Real Name: Jerod
Real Name: Jerod
EngineMasters dyno tested a metal fan with no clutch, a metal fan with a clutch, and the flex fan you linked above. The metal fan with a clutch had the least amount of power loss when compared to no fan at all. The flex fan was also very flimsy and they made a point to show that on the episode.
LCE sells a lot of quality parts but they do have some gimmicks listed for sale. The flex fans as well as the throttle spacers for the EFI motors like ours are some of them.
326WHP 347TQ
Old 01-18-2024, 12:47 PM #43
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Originally Posted by FinnCorlein View Post
I see that your post is from 4 years ago, so I hope you've found a solution to the temperature issue with your 4runner since then. Upgrading the radiator and switching to an electric fan are valid considerations to improve cooling performance. If you've already taken these steps, I hope your 4runner is running smoothly now. By the way, if you're ever in need of ceiling fans for your home, you can explore options to buy ceiling fans in bulk. They offer a variety of fans that can enhance ventilation and comfort in your living space.
yeah because a ceiling fan will work with a radiator. good job scammer!
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 02-19-2025, 12:45 AM #44
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of
Real Name: Blair
Well.....I had a 1970 Buick Riviera GS with a 455 and the Kenne-Bell Flex Fan was one of the best cheap upgrades I did. Kept it cool at the red light at low RPMs and robbed less HP at speed.
Y2K LTD/E 265K
ago , coolant , radiator/fan , water , year
My radiator is too young to die! (V6 radiator leak pics) RunnerAK 4th Gen T4Rs 35 02-28-2019 05:34 AM
Overheated due to leaking radiator, getting misfires after installing new radiator pclausen 3rd gen T4Rs 97 05-09-2017 11:54 PM
FS: NEW 3rd gen 4Runner Toyota Radiator, Radiator Cap, Coolant - SF Bay Area, CA - $ TxnBluDvl For Sale: T4R Items 2 04-08-2017 03:23 PM
Oil in my radiator, now what/\? jbrianyc General Discussions 6 04-16-2014 04:56 PM
Will this KOYO radiator work as an OEM radiator as far Gavin S. 3rd gen T4Rs 9 06-08-2010 11:04 PM
