Real Name: Blaine
Real Name: Blaine
Another p0420
1997 T4R 3.4 4WD (non-cali) 237k mi
Recently I went on a 4 hour road trip down to Florida for a bachelor party. On the way there the CEL came on. I have one of those cheap chinese made scanners that I pair with the InfoCar and Car Scanner apps. I checked the codes. It came back as:
Confirmed
p0125 Insufficient coolant temperature for closed loop fuel control
Pending
p0130 Heated oxygen sensor (HO2S) 1, bank 1 -circuit malfunction
p0133 Heated oxygen sensor (HO2S) 1, bank 1 - slow response
I checked out the live data and the Oxygen sensor 1 bank 1 Voltage was 0 V and Oxygen sensor 1 Bank 1 Short term fuel trim was 0%. After some research, it appeared that my upstream o2 sensor crapped out. I came home and ordered a new upstream denso o2 sensor. Cleared the codes and everything appeared to be fine on the live data reading...
Days later I got the dreaded p0420.
Confirmed
p0420 Catalytic Converter System Bank 1 Efficiency Below Threshold
I figured I'd go ahead and replace my downstream o2 since I replaced the upstream sensor. Cleared the code and put in the new o2 sensor. Everything was working fine and I even gained MPG... a blessing in a lifted T4R on 33" tires. Everything is still working fine, but now I get the p0420 CEL code every few days. Anyone else have this experience? I'm gonna try to look for exhaust leaks.
Throttle body is clean. OEM MAF is maybe a year old. Spark plugs and wires are new.
pls don't be the cat pls don't be the cat pls don't be the cat
1997 Toyota 4Runner SR5 4WD
Birmingham, Alabama - Central Alabama 4Runners
Go Avs Go | Roll Tide
BlainePrickett.com
