Old 02-28-2021, 10:13 PM #61
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by cheezPoof_4x View Post
I'm nearly 2500 miles on them in a month, lol. Putting in work on and off road. I'm really happy with the product. One of my biggest concerns was how they felt/handled on washboards. Night and day difference! Even at higher tire psi. I am curious though, how much more flex/travel/articulation I may get out of longer sway bar end links and/or panhard bar drop bracket. I've read, up to another 1" of travel, but I haven't been convinced yet either way.
As far as needing the strut packer or whatever it's called to fix the "Toyota lean", I opted not to and it's flush even in front. My first measurement was nearly 1/2" lower in the rear driver side compared to the passenger rear, but that could've been on a full tank gas. As far as I'm concerned it sits pretty damn level, or negligible to the eye. I'll post some pics on/offroad, but I don't like how some appear to show up and others don't on this app.
Feel free to ask any more questions you may have. I wish Dobinson's would credit me something on future purposes for their mistake on assembly, but I was told that it's "normal" to have to make some adjustments. They should state that online and/or upon ordering.
Sent from my SM-G965U using Tapatalk
Been reading through this thread again, trying to decide, then I saw that you talk of using a panhard brakets. I was under the impression if a person went 2 inch they would not need a diff drop or the panhard bracket. ....only when you get to 3 inch and above.
so are you using either of them and were you told you needed to ?
Old 02-28-2021, 10:49 PM #62
cheezPoof_4x's Avatar
cheezPoof_4x cheezPoof_4x is offline
cheezPoof_4x is on a distinguished road
I haven't bought or installed a panhard or diff drop. I was considering it, IF it gave me more articulation.
Just the lift and tires. Straight forward install.
Sent from my SM-G998U1 using Tapatalk
1998 Limited 4x4 w/E-Locker
262k miles w/ALL records
All stock except Tall rear springs and WeatherTech mats
cheezPoof_4x is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 01:24 PM #63
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by 3bears View Post
well that stinks.....the source listed above, when I went through the " cart" to check prices.....do not ship to fairbanks alaska.......argggg
I will have to come up wiht a solution this spring, as now my stock system rubs at times with 70 seires winter tires ( rub in front) , and I got the typical sag issue in the back, and my summer wheels and tires are 265/75/16 ko'2....dont think they will fit with this worn out suspension on this rig. 285k and looks all stock ( suspension)
well just got an email back,
the good.... they will ship to alaska
the bad......out of stock till end of march at earliest
Old 03-01-2021, 01:29 PM #64
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
FWIW, I originally designed the PCK for my 2" OME lift kit. (then made it accommodate taller lifts)
Don't believe the advertised heights of lift kits - the actual lift depends largely on truck build-out and typical load. My OME 2" was taller than that in reality.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 01:33 PM #65
Thanks @eimkeith , I've looked at your products for consideration Dobinsons 2.0" Lift kit
Old 03-01-2021, 01:56 PM #66
Real Name: 3 Bears
Real Name: 3 Bears
thanks.
I used your brackets on the last build, and the fit and function was excellent. Loved the way that rig turned out after lift....well till it was totaled.
Maybe I will use them on this current build. Still trying to decide if to lift it 2 inches or just go 99 talls. I played more in the lower 48, than I do up here and not sure I need the 3 inch lift again.Talls would be cheapest, and this one needs lots of other love ($$$) in other directions, like every bushing in the suspension to name one. Then again I have a new ARB and winch sitting in storage, as I totaled the other one about 3 weeks b4 installing those, so might need the 2 inch lift for the added weight.
Waiting to find out how much and how long the dobinsons are gonna take to get shipped here, after they come off back order.
thanks again for your quality product
Old 03-01-2021, 04:42 PM #67
da_dre da_dre is offline
da_dre is on a distinguished road
Can you guys or others report back on any spring settling or height changes? Dobs says it "may" settle up to 5mm. Thanks
@raty4R @cheezPoof_4x @AUStricken
Dobinsons 2.0" Lift kit-screenshot_20210224-222126_chrome-jpg
da_dre is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 02:01 PM #68
Real Name: 3 Bears
Real Name: 3 Bears
just a nice guy. Those thinking of going the dobsion route with exit off road....Mike has been a big help with fast reply
Old 03-03-2021, 01:29 AM #69
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by da_dre View Post
Agree, what Dobs set up are you going with?
if I do it, c59-134 and c59-137v
shipping alone to me is 400+.. yuck
so with shipping that puts me at almost 1500. shipping stuff is one of the "problems" of living in Alaska....
fishing, hunting, back roads, few people is not one of the problems
Old 03-10-2021, 07:53 PM #70
raty4R's Avatar
raty4R raty4R is offline
raty4R is on a distinguished road
raty4R's Avatar
Mine settled down to 23 in the frt and 23.5 in the rear. center of hub to bottom of SR5 fender flare, 285/75r16
raty4R is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 01:26 AM #71
Real Name: 3 Bears
Real Name: 3 Bears
at how any miles or time did it take to settle to that point ?
Old 03-11-2021, 07:30 AM #72
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
did you install the conical bump stops and trim packers? If with trim packers, what thickness did you use?
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 06:37 PM #73
raty4R's Avatar
raty4R's Avatar
It's been about 8 or 9 months and prob 1500 miles since I installed the springs and shocks. I didn't need the trim packer, my fronts were level. The fronts also were level with the old suspension lift.
Old 03-11-2021, 06:58 PM #74
lauchris203 lauchris203 is offline
lauchris203 is on a distinguished road
@raty4R After 1500 miles, any differnce in ride quality? Thinking about going with 5100s all around with dobinson coils.
lauchris203 is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 02:40 AM #75
Real Name: 3 Bears
Real Name: 3 Bears
im thinking that direction myself now that bilsteins is available again
aus , dobinsons , kit , market , regarded
Dobinsons 2.5" lift kit Daven75 5th gen T4Rs 13 05-31-2022 11:10 PM
FS: Dobinsons 1" F/R Spring Lift for TRD Pro - $375 Baltimore, MD kaikaikai For Sale: Suspension/Wheels/Tires 1 07-15-2020 02:19 PM
FS: Dobinsons C59-599 Rear Coil .75" Lift OC/CA onepremiere For Sale: Suspension/Wheels/Tires 2 09-25-2017 08:48 PM
