Old 08-25-2020, 06:48 AM #1
Gattaca Gattaca is offline
Gattaca is on a distinguished road
Rough Idle - Warm Start
2000 Limited Runner. Starts fine cold but if I drive for 10+ minutes and then turn off to go in a store or something, when I start back up it idles rough.
It will even out as soon as I get back on the road.
Gattaca is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 08:35 AM #2
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
Is it misfiring (throwing any codes)? When I had a warm start rough idle it was a bad fuel injector and was throwing a P0303 code.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 10:04 AM #3
No CEL or anything along those lines. Would a code show up without it?
Old 08-25-2020, 10:42 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You could have a pending code which won't set a check engine light. You would need to use a scanner to retrieve it.
Old 08-25-2020, 07:39 PM #5
pelantire pelantire is offline
pelantire is on a distinguished road
Here are some cheap things to try
- Spark plugs and wires, NGK/Denso only
- Clean your Mass Air Flow sensor (use a proper MAF cleaning spray)
- Clean your Throttle body and Idle Air Control Valve
- Fuel filter (often neglected)
- Check for vacuum leaks, inspect all the rubber hoses for cracks, do a smoke tests
pelantire is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 09:28 PM #6
Greyhome's Avatar
Greyhome Greyhome is offline
Real Name: Graham
Greyhome is on a distinguished road
Greyhome's Avatar
Real Name: Graham
X2 on this. I recently had a slightly rough idle and a bit of hesitation if I got on it at highway speeds. Giving the MAF sensor (really cleaning it, pulling it out of the airbox) and cleaning the throttle body smoothed it right out. Fuel filter going in this weekend for good measure
A couple of years ago I had a real misfire due to a cracked exhaust valve and it didn't throw codes for months. Simple stuff first, process of elimination. If you try all the above and it's still giving you trouble, only other things I'd check are ignition coils (not likely), PCV valve/hose, and then get yourself a compression test to rule that out.
Greyhome is offline   Reply With QuoteReply With Quote
back , idles , rough , start , store
1987 22RE Turbo Rough start and rough idle. mastermechanicjt Classic T4Rs 4 04-25-2017 08:40 PM
Intermittent Warm Start Rough Idle 58rennur4 Classic T4Rs 0 02-26-2015 07:46 PM
Rough Idle when Warm / Carbon Build up on 3 of 4 plugs changedsoul 3rd gen T4Rs 18 10-11-2011 12:57 AM
rough idle after warm up????? poof Classic T4Rs 10 05-07-2011 08:45 PM
Dies after start/low idle on warm start Hogmoss 3rd gen T4Rs 3 10-19-2009 11:36 AM
