Old 08-25-2020, 03:54 PM #16
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
Amazon.com: Coil Spring Compressor Tool, Orion Motor Tech Macpherson Strut Spring Compressor,13/16in Socket 1/2in Drive: Automotive
I have used this type for years...and I am pretty sure I will never again. Every time I was afraid...some times big time and just prayed...dont come loose....ive done all different styles of using them...on all kinds of cars....even mounting to a work bench. Even using 3 at a time instead of the two you normally get. work them down slowly and equally and the same with removal. To me they are high risk. But im older now and not so risky in stupid things I do.
I still have 2 sets in my garage.
with 2 sets in garage and tons of tools, i just had my tundra springs and billies assembled at a shop....just not worth it to me anymore...
wanted to try the method of jacking up your lower a arm.....just did not. I bet that works good and is safe...spring cant come flying at you with amazing force.
but..if you want to use those hook things...made now in china....go for it...just be real darn careful...save the beers till after your done
thats my 2 cents of info
Old 08-25-2020, 04:07 PM #17
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by 96RedRunner View Post
Cancel that order.!! Use the vehicle and floor jack.
I hate spring compressors and paying. Did this on 96Red and new 01
Did my Tundra 5100's 3 times, just installed 6112's twice playing with lift, position 3 & 4.
Figured it out in 2012. Have knuckle and CVA out of way, LCA swinging free,
top hat hung in place, put strut in place bottom bolt in place, compress strut with jack, top stem bushing washer nut torque it.
6112's settle in may need to play around, 1k mi on them now might be a while.
I do NOT doubt this method at all, and was tempted to try, and have heard others on this forum say they use this method. but for me I would like to see pictures or a video doing this on a 3rd gen 4runner....not 4th gen ...but thats just me
Old 08-25-2020, 04:19 PM #18
NJ-4Runner NJ-4Runner is offline
NJ-4Runner will become famous soon enough
Originally Posted by Nickname View Post
Yes, sorry. However, I believe the same would apply to a 3rd gen except you would undo the lbj instead of the two bolts near the lbj that the 4th gen has. My buddy has a 3rd gen and used the no spring compressor method. Idk if he had a 2" lift, but I know he has a lift. I haven't been under a 3rd gen in a bit to remember the front suspension setup.
I would also like to see a video of someone doing this on a 3rd gen. In order for this to work on a 3rd gen that lower control arm would have to be swinging free, anything taller than a stock strut/spring setup would require that lower control arm to come WAY down.
NJ-4Runner is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 05:20 PM #19
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
I have Boss coilovers, which are externally threaded adjustable coilovers - there's no top hat and nut to remove, and from what I can tell, the spring has to be preloaded in order to remove or install the collars. I can't use the weight of the vehicle to disassemble these, although I can see it being possible with OEM style shock assy. In full disclosure, I haven't cranked the collars down to the very bottom of the shock to see if the compressor hooks will fit between the coils and between the spring and the shock, but I will be surprised if they do, especially with any preload on the spring.
I guess I'll give it a go when I get time to take it apart, but plan B will be a shop with a spring compressor.
For posterity, I'll add that I used to work for a company that built these shock assemblies for OEMs. I've seen them come apart when they weren't supposed to due to defective threads on the shock shaft, improper assembly, etc., and it's violent to say the least. Whatever method you use, be careful.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 09:30 AM #20
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I do NOT doubt I would like to see pictures or a video doing this on a 3rd gen 4runner....
With all you've done and figured out already this a piece of cake.
All I did was look at it, walk it through in my head, go for it.
Method worked having jack coming at it from front of truck, from side jack wanted to roll out when you loaded up spring tension.
The stem is started into top hat when spring starts loading up, bottom bolt in place, the assembly is captured by lower mount and top hat where it gona go, no where.
You control speed of things loading up with jack, check alignment of things as you load up spring. I left top hat nuts hand tight till things were in place torqued em all same time.
Go old school, rely on the gray matter between your ears, started wrenching before the Net was invented, way I look at it.
Old 08-26-2020, 09:54 AM #21
Real Name: Mark
Real Name: Mark
Can only speak of what I've worked with, throw in OME. What you have wing it, I'd have to be there.
With coilover can only go so far unloading mounted up, is that far enough to unload spring.
You hit a WTF, stop and think about it.
Old 08-26-2020, 10:07 AM #22
Real Name: Mark
Real Name: Mark
I do NOT doubt I would like to see pictures or a video doing this on a 3rd gen 4runner....not 4th gen ...but thats just me
Let's do it, you be cameraman, hot n humid hurricane season where I'm at, some Alaska is right up my alley.
Old 08-26-2020, 10:16 AM #23
Real Name: Mark
Real Name: Mark
That's right, like I said swinging free, Cam adjusters loosened up nothing attached to LCA.
Old 08-26-2020, 10:21 AM #24
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN will become famous soon enough
TodiN's Avatar
Real Name: Todi
I just installed my struts using the no spring compressor method last night. Link below for a good write up.
OME Install - no spring compressor - Toyota 120 Platforms Forum
I have used this method several times and it has always worked. I used it with Bilstien 5100s with the stock spring set at 2.5" and with a 1.5" spacer and the shock set at 1.75". The second combo was difficult, but still doable without a spring compressor. Given that it netted ~3" of lift I think a 2" lift spring would be doable using this method.
Some important tips:
1. Remove the sway bar. This is super easy and you will save a ton of hassle later on.
2. Make sure you jack your vehicle up as high as possible so that you have plenty of room to push your lower control arm down with the pry bar.
3. Put a jack stand at the opposite corner of the vehicle. This will take some "flex" out of the vehicle and make it easier to pry down.
4. Have a buddy help you. A second set of hands makes this job super quick.
Hope that helps!
Edit: I did not even loosen the CAM bolts. Just undid the two lower ball joint bolts.
Good to know it can be done by disconnecting the sway bar; I've always done it by loosening the CAM bolts.
I can vouch for this method. I've done it several times installing the FJ Pro suspension, Bilstain and few weeks ago on Ironman 4x4 Foam Pro. Independent on method, you do need another set of hands unless you want to suffer few days from back pain ... don't ask me how I know
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
TodiN is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 11:05 AM #25
Real Name: Mark
Real Name: Mark
Sorry for your pain, my azz was planted on a roll around stool whole time guess results vary, where you do it makes a difference I bet.
Old 08-26-2020, 12:13 PM #26
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
mine was on a rolling Home Depot bucket I need to get one of those mechanical shop chair
2018 TRD OR
coil , coilovers , coils , fit , spring
**Rear Coil Spring Discussion - The Perfect 3rd Gen Rear Spring** rickashay 3rd gen T4Rs 344 03-27-2024 03:53 PM
Spring compressors for KING coilovers? Grug556 5th gen T4Rs 20 11-18-2021 09:26 PM
Toytec lift kit for TRD Pro...need spring compressors? stephan07 5th gen T4Rs 8 12-22-2017 10:45 AM
Coil spring compressors djsim1056 4th Gen T4Rs 9 06-25-2016 10:38 AM
99 talls in the rear of an '02 w/o spring compressors? RunninOnBlue 3rd gen T4Rs 5 08-26-2011 02:54 PM
