Old 08-25-2020, 03:09 PM #1
Supra725's Avatar
Supra725 Supra725 is offline
Real Name: Al
Supra725 is on a distinguished road
Supra725's Avatar
Real Name: Al
Po305
Hey guys,
Lately I been having an misfire.
In the beginning, if I drive to work one smooth drive, the engine runs fine, no issues, no misfire
However if I do stop and go, like starting and going to places. It throws an misfire.
If I let it cool back down, the misfire doesn’t happen.
On the other cylinders, it doesn't have that problem.
Where should I go to begin with it? Change out the spark plug or the coil pack?
The rig is sitting at 406k miles and I believe is still on the Oem coil packs from 1999.
99' 4runner Sr5 4wd
Goodyear | Piaa | Hella | Smittybit | BAMF |
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Supra725 is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 03:48 PM #2
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Originally Posted by Supra725 View Post
Hey guys,
Could try swapping the coil packs and spark plugs see if the misfire moves. Measure resistance on plug wires..
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 04:08 PM #3
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
Another warm start misfire thread... popular topic today. Mine was a bad fuel injector but rule out the easier stuff first.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 04:21 PM #4
Supra725's Avatar
Real Name: Al
Supra725's Avatar
Real Name: Al
Jkoni426,
Was yours having similar symptoms as mine too?
How much was it for you to replace the injector? Did you swap other things out like spark plug or coil pack before that?
Thanks
99' 4runner Sr5 4wd
Old 08-26-2020, 04:48 PM #5
spartacus's Avatar
spartacus's Avatar
P0303, Did all of the reguler stuf,f spark plugs,wires, Maf, coils etc In the end replaced injector wth Gb remanufactured injector went bad after a few weeks went with the pricey oem which fixed it.
Old 08-26-2020, 06:53 PM #6
HiLife HiLife is offline
Worked on a friends P0302. Pulled all the coil pack and inspected the plugs. Dried out the and cleaned with carb cleaner the fuel soaked #2 plug. Put everything back. Still P0302. Swap coil packs between #2 and #4. Got P0302, P0304.
No codes after new plugs and new #2 coil pack.
OP, make sure to address your P302 quickly or risk burning up/clogging your cat.
Old 08-26-2020, 06:58 PM #7
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
Give it a basic tuneup before you start anything. New plugs, wires and air filter. Clean the MAF and reset the computer. At that milage I would do a compression check next. Then you can start narrowing down the problem
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 10:26 AM #8
Real Name: Joe
Real Name: Joe
Jkoni426,
Thanks
Same symptoms as yours. I could make a single trip anywhere no problems but if I made a stop along the way and restarted warm a few minutes later it would misfire (P0303). My plugs were somewhat new and I already tried swapping coils and did a compression check etc, so I tried plug wires since they were the originals even though they still ohmed out as good. When that didn't fix it and after reading other threads online about the same thing, I knew it was the injector.
I got 6 GB remanned injectors from rockauto also but mine have been fine for the past year or so thankfully. I swapped them out myself for just under $200.
Old 08-27-2020, 12:44 PM #9
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Funny, mine has new coils, plugs, and injectors and I get a very slight miss when I start and drive it warm. Just a slight stumble when idling at a stoplight enough to notice but not enough to throw a code. I always thought it was just my 4Runner that did this but looks like it's more common than I thought. The engine will sometimes run very lean idling when this happens, as lean at 17:1 AFR. After about 5 minutes of driving it goes away and goes back to normal and all power is back.
326WHP 347TQ
Old 08-27-2020, 12:59 PM #10
Real Name: Joe
Real Name: Joe
Are the injectors brand new oem? I took a chance with the remans but my thoughts are the circuitry or whatever is fine when cold but expands and/or breaks down when hot, breaking the circuit inside the injector and causing a misfire. Mine wouldn't throw a code every time, would just idle real rough shaking the whole truck. I did get a flashing CEL once going up a hill. Mine would sometimes feel like it kicks back in and be fine as well. Gotta be an intermittent bad connection inside old injectors.
Old 08-27-2020, 01:12 PM #11
Real Name: Jerod
Real Name: Jerod
They are also re-manufactured. That could be the cause but I'm not sure. Could make sense when the engine sits, since the injectors are cooled by the fuel and when the fuel stops moving it warms up in the engine bay. Get some cold fuel flowing and the injectors are back to normal? Could be plausible.
326WHP 347TQ
Old 08-27-2020, 03:09 PM #12
itskohler's Avatar
itskohler itskohler is offline
itskohler is on a distinguished road
itskohler's Avatar
I get an intermittent stumble on mine, and just like you its not enough to throw a code. Mine stays as the RPMs go up though and it feels like a rumble ever 1 to 2 seconds depending on RPM. I'm really hoping its not a bearing in the engine and its just something to do with the injectors.
98 Limited - 2010 Triumph Daytona - 2017 GTI
itskohler is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 05:21 PM #13
Supra725's Avatar
Real Name: Al
Supra725's Avatar
Real Name: Al
well, I tried with new plugs, wires and even an coil pack. im still having issues.
now im going to swap out the injector as that's the last thing there is to be done. the only cylinder is 5 and nothing else.
what do you guys recommend for the injectors? my mechanic quoted me $810 for oem injectors out the door. I'm going to have my friend help me and save some $$$.
is there alternate fuel injectors that performs as well as oem at a decent price? go for remanufacture? Lce injectors? what else do you I need for the parts?
thanks
99' 4runner Sr5 4wd
Old 02-11-2021, 05:46 PM #14
spartacus's Avatar
spartacus's Avatar
thanks
Just replace the #5. I replaced #3 with oem when I had a misfire.
Replacing injector is fairly simple.
This might help too.
fuel injector replacement
if you have time you can take them out and send em to Home
Old 02-11-2021, 06:40 PM #15
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I recommend these guys for fuel injectors: Part Finder – MotorWest Performance
begin , coil , drive , misfire , problem
