08-25-2020, 10:41 PM
Real Name: Devan
Real Name: Devan
Adjustable Sway Links (?)
Hey all,
Like many of you I got some of MStudt's extended/adjustable sway bar end links, which I recently installed this weekend. However, I'm not exactly where to set these things - I took a gamble on the rear ones and it seems fine from what I can tell, but the front has a popping I just can't get rid of. When taking a turn, that side of the vehicle will pop respectively (so on a left turn, the drivers side will pop as the body weight rolls to the right, etc). Not a small pop either - loud and strong. Initially i thought the bolts were too tight, and the ones at the heim joints were visibly too snug so I loosened them a bit and now the pop isn't as sensitive, but still there the second you stop driving like a grandma. Currently I have the front links extended out a bit, but thought about taking them down as short as they can go and starting from there. (I have a Tundra TRD lift up front)
Any thoughts on how to properly set and adjust these links as needed?
08-26-2020, 12:13 AM
Hopefully MStudt would chime in.
1999 T4R SR5 w/ ARB rear locker - Rocky
2018 T4R OR - Bear
08-26-2020, 07:44 PM
Real Name: Devan
Real Name: Devan
I sent him a message a couple days ago but have yet to hear back and was curious if others could help. You'd think, for $200+, they'd come with SOME instructions but I guess not. So far, not very pleased with this drunk purchase tbh, but when they're cheaper and much heavier than an OEM set from McGeorge I guess it's not too bad, especially being rebuildable
Edit: I should clarify if i turn hard enough I actually do get a pop in the back as well, and the one of the pops up front feels almost directly under the driver seat, leading me to believe it's the links. Can't replicate it by rocking the vehicle tho
08-27-2020, 09:00 AM
LOL'd at drunk purchase
I ran these and had the popping in the front as well. I couldnt do anything to make it stop. Eventually just decided to remove my entire front swaybar, and endlinks and test drive it. No more popping. Sway bar has been off of the front for 4 months now, and ill never put it back on. Drives amazing.
The rears are silent for me. You've got to get those really tight.
The only issue in the rear is that they're hitting my girthy boi Rokeman LCAs when offroading, which is OK by me
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
08-27-2020, 11:58 AM
I've done the same. Had popping in the front, pulled the front off, been driving with it off for at least 10 months now. Would really love if there's some way I could make my 200$ purchase usable. Kinda do regret getting these.
2000 SR5 - Build Thread
08-27-2020, 11:07 PM
Real Name: Devan
Real Name: Devan
I thought about taking it off but I'm not sure about the body roll. I haven't heard anybody complain about popping with OEM links, so maybe these are too stiff and beefy?
Knowing how simple they are, I could make a lighter version at work and see if they fix the problem, if that's later determined to be the issue.
08-28-2020, 12:53 AM
I'm running the same Endlinks without any problems.
Have you adjusted them so that the Swaybar is parallel to the ground?
Are the jam nuts tight?
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
08-28-2020, 01:21 AM
I had similar issues... popping in the front. They worked well initially but the popping in the front became unbearable so I reverted back to 2nd gen 4runner end links. I am wondering if I didn't adjust the height properly. I should have probably contacted MStudt. I like these end links and once I have some free time I would probably try to put them back.
2018 T4R OR - Bear
08-28-2020, 08:09 AM
Real Name: Mark
Real Name: Mark
Originally Posted by Herculean T4R
I had similar issues... popping in the front. They worked well initially.. I am wondering if I didn't adjust the height properly...
They worked well initially they should again, unless damaged, Rod ends known for rotating.
It's my understanding parts need to be in correct sequnce/position, pic in post shows it search it.
From factory bar is parallel with frame rails at ride height. As you lift keep it parallel with frame, same with Panhard designed level keep it level.
08-28-2020, 09:56 AM
Real Name: Devan
Real Name: Devan
Yes and yes. I'm wondering if maybe my bushing arent tight enough? How tight/squished should they be?
08-28-2020, 10:14 AM
Real Name: Mark
Real Name: Mark
I've torqued them to spec and beyond, beyond has worked better.
With whatever it takes to grab them I tighten till they won't turn, have yet to break one they stay in place.
08-28-2020, 10:23 AM
As easy as it is to remove the front links, I say take them off and go for a test drive. I did this and I'm very glad I did. The IFS really takes bumps in the road better with it off, and rides smoother. Less vibration in the steering wheel, and the suspension is actually able to move independently.
Now, as far as body roll, it's going to be a personal preference, and it'll depend on your front spring rate.
I hardly noticed roll at all. Yes, it's there, but it's not like driving a tractor or something. In a way its more predictable.
08-28-2020, 12:34 PM
Real Name: Devan
Real Name: Devan
Duly noted, will tighten them down before I leave work
I might give it a try one of these days. Currently I rub a little bit on my front fenders with a little recoil, so I might wait until I put my bumper on or else I'll really hit them
08-28-2020, 11:55 PM
Real Name: Devan
Real Name: Devan
Tightened them up, not sure if it really made a difference. Currently my fender rubs my tire ever so slightly when bouncing/dipping hard through a turn, so it can be tricky to tell. I definitely still had some very strong, hearty pops driving home though, just not sure it they were any better than before.
Here are pics of the length they're set at and how parallel the bar is to the road. Or should it be tilted to match the upsweep in the frame, is that what you guys are saying? Perfectly flat ground here
Update: maybe these pics work?
08-29-2020, 02:31 AM
What brackets are holding the inner part of the Swaybar to the 4Runner? Can you post a pic of those? I had some crazy sounds with the Energy Suspension brackets and when I switched them out for (Dorman 928-361) and got them good and tight that quieted things down a lot.
