Old 08-28-2020, 09:21 AM #16
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Updated, anything else?
Old 09-02-2020, 07:29 PM #17
jross20's Avatar
jross20's Avatar
Do you guys think this is sticky worthy? Or perhaps it could be added to preexisting sticky? I was hoping this could be used to help the community out in the long run
Also, any updates I should add?
Old 09-12-2020, 02:34 AM #18
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough Fiffa will become famous soon enough
Fiffa's Avatar
The 4th gen 5160's are (basically) the remote reservoir version of the 33-187174 (extended travel 5100's)
PN: 25-227611
2.5"-4" of lift option for 3rd gens
Collapsed Length (IN) 14.83
Extended Length (IN) 23.5
~$380/pair (that's what I paid at Wheelers)
Fiffa is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 01:58 PM #19
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
I think toytec has a few setups that you may not have on there.
Aluma series, ultimate lift, Elka, and ebaich kit.
Toyota Lift Kits - Complete & Suspension Lift Kits For Sale - Toytec Lifts
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 09:30 AM #20
jross20's Avatar
jross20's Avatar
Hey guys I'll try to add these today
Old 11-28-2020, 07:55 PM #21
jross20's Avatar
jross20's Avatar
Updated.
Apologies for the delays.
Also, I am currently working on figuring out the maximum collapsed measurements for stock bump-stops. I believe this will help folks better pick out and project their lift.
Like right now I think my rear bump-stops are too long as I bottom them out with the smallest speed bump...haha. The OME shocks i have still seem to have travel left so I will try to shorten the stops.
Old 12-25-2020, 07:52 PM #22
culiced culiced is offline
culiced is on a distinguished road
25-237429 tundra 5160. has anybody tried these? ive been searching with no luck. from what i gathered the 4th/FJ 5160 25-227611 is valved a little too soft. From what ive gathered bilstein indirectly said its closest valving is 170/60. curious to see what the valving is with the tundras
culiced is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 02:49 PM #23
Fiffa's Avatar
Fiffa's Avatar
Paired with the Dobinsons C59-210v coils (progressive), the 4th Gen 5160's feel pretty well matched - not too firm, but definitely not soft. I'm also running a fully loaded storage drawer system in back and full Sherpa roof rack, so I'm sitting at about 3" of lift (24" hub-to-fender) with the roughly extra 300 or so pounds resting back there.
I thought I read somewhere that Tundra rear shocks tend to be more soft because of the stiffer leaf springs? I don't have much offroad experience yet with my setup, but I have been reading up a ton this last week on the relationship between springs and shocks for offroad applications, so it'd interesting to see if we could start a comparison thread based on combinations to help compliment this one and the shock discussion. It's probably going to be more anecdotal in the long run, but it would definitely get people closer to a worthwhile setup without so much trial and error or settling for something that may be popular but not the best for their needs.
'00 'Get Lost' Build
IG: get_lost_fiffa
Old 02-22-2021, 12:51 AM #24
lawrencesam74's Avatar
lawrencesam74 lawrencesam74 is offline
Real Name: Samuel
lawrencesam74 is on a distinguished road
Real Name: Samuel
We also have the Eibach pro-truck lift kit, which offers some Eibach shocks. I haven't heard very much about them and how they ride but I would really like to hear some feedback as they are pretty affordable.
Eibach P/N is E80-82-005-01-22 for the kit
lawrencesam74 is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 04:25 AM #25
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
with an extended length of 25.69" and a collapsed length of 15.22", wouldn't that be too long?
also, the wheeler's website says a 46mm diameter design. is that the body diameter or the piston diameter? if it's body diameter, then it's smaller than the 5100 shock
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 01:04 PM #26
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Those would be really long, and I'm not sure if 2nd gen tundra rear shocks will work for 3rd gen 4Runner's.
My understanding of 5160 shocks is it's the same piston size as a 5100 shock, but with an external fluid reservoir for more fluid capacity to reduce how quickly the shock fluid will heat up and cause shock fade.
Old 02-22-2021, 02:03 PM #27
Leaf springs are somewhat 'self damped' due to the friction action when they move - so shocks meant for leaf spring applications will be softer than equivalent rate coil sprung applications.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-22-2021, 03:20 PM #28
Fiffa's Avatar
Fiffa's Avatar
As far as I know, you're correct on the component similarity to the 5100's. The resi is designed more to equalize dampening throughout the stroke than anything else. The reduction/elimination of aeration (heating) is an added benefit, but more of a quality attributed to the monotube design.
IG: get_lost_fiffa
Old 02-22-2021, 03:22 PM #29
Fiffa's Avatar
Fiffa's Avatar
This is why it'd be nice for manufacturers to actually spill the beans on dampening specs!
IG: get_lost_fiffa
Old 02-22-2021, 09:08 PM #30
Has anyone in here used the Koni shocks for the N185 4Runner and have the extended and compressed lengths?
embedded , excel , jrosss , shock , thing
xreas replacement - shock vs shock/spring replacement amheck 4th Gen T4Rs 21 11-14-2017 08:21 PM
What shock or shock/coil combo would you choose? Levinz11 4th Gen T4Rs 9 04-07-2015 09:07 AM
Do LC shock bushing match stock lower shock bushings?? Jc12 3rd gen T4Rs 2 04-10-2012 07:54 PM
List your MPG here please NickT916 5th gen T4Rs 61 11-23-2011 04:49 AM
Your top ten car list SkylineGTRracer General Discussions 47 02-12-2011 01:04 AM
