11-19-2016, 12:36 PM
ECM reset
Can anyone direct me to a thread with instructions on how to reset the ECM? I've searched, but can't find anything. Recently did major maintenance on my '97 3rd gen V6 and I'm still having sluggish acceleration. Thinking an ECM reset might need to be done now.
Thanks!
11-19-2016, 12:40 PM
Remove negative battery terminal for 10 minutes or so.
Removing the EFI fuse might do it as well but I'm not sure.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
11-19-2016, 01:03 PM
Real Name: Alex
Real Name: Alex
The quick way to do it is to remove the negative terminal and touch it to the positive terminal. It discharges all the capacitors that you would otherwise have to wait 10 mins for them to do it on their own.
1998 T4R, 2.7 4wd/5spd swap build thread
11-19-2016, 04:29 PM
Location: Stationed in Camp LeJeune, home is Conover, NC
Please tell me you mean to remove BOTH terminals and touch them together.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
11-19-2016, 07:32 PM
Real Name: Alex
Real Name: Alex
Yes yes, Lazy typing
11-19-2016, 10:18 PM
I'm not sure if it would make a difference.
11-19-2016, 10:21 PM
Try it and let us know how it works out.
Take a video while you're at it please.
Not saying it won't, but I don't have the balls to try to ground a positive terminal out.
11-19-2016, 10:41 PM
easiest was is to pull the EFI fuse under the hood for 60 seconds. that resets the ecu. (resets CEL, fuel trims)
if you touch both battery cables together you loose clock, radio memory which can be a pain to reset. so that way it not that quick by having to reset all that.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
11-19-2016, 11:59 PM
Thanks for all the advice. I'll start with the EFI fuse first and see if that works.
11-22-2016, 05:44 PM
The ground would be lost when the negative cable was removed.
11-22-2016, 06:55 PM
Damn I didn't know pulling efi fuse killed ecu power?
11-22-2016, 07:33 PM
Real Name: Ron
Real Name: Ron
The EFI fuse kills some of the ECU power, notably the part that backs up the memory of learned values and CEL codes. Other functions of the ECU remain powered up without the ECU fuse in place, but not enough to make your truck run.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
12-08-2023, 11:57 AM
i pulled the negative battery terminal for 12hrs...yet the vsc, stability, brake icon didnt erase.
note i had the 2 rear wheel speed sensor not detected error prior to the disconnecting the battery for 12hrs.
i thought it would erase all cels, til the car is driven again, before the ecm will detect the wheel speed sensor error again.
how do i reset the ecm completely? the method i saw on youtube didnt work either
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
12-08-2023, 02:22 PM
As far as I know, you must manually scan and clear stored engine codes.
You can do that with any cheap OBD reader.
The 4Runner Show
12-08-2023, 03:42 PM
This is the 3rd gen forum... you'll want to try the 4th gen. We don't have stability control and a number of other systems you have.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Do i have to reset my avg mpg??
MikesToy |
4th Gen T4Rs |
12 |
01-16-2014 01:45 PM |
ecu reset
LBeard87 |
Maintenance/Detailing |
6 |
10-10-2013 03:39 PM |
ecu reset req'd?
ixcocoyxi |
3rd gen T4Rs |
6 |
05-08-2013 11:24 AM |
reset. need help
Snookster |
Engines / Suspension / Wheels / Tires / Audio / Accessories |
3 |
12-03-2007 04:52 PM |
