Old 08-28-2020, 10:31 PM #1
da324 da324 is offline
da324 is on a distinguished road
AC making gurgling noise under glove box.
I have a 2001 runner with 187k. The other day when i got home I noticed a gurgling sound coming from around the passenger dashboard area. I know the blower motor is there and I believe the ac evap is there too. The sound subsided the longer I sat and it stopped immediately when I shut the key off. I went back later and turned the car back on, but I didn't engage the ac, and there was no noise. It's done this a couple of times, but never before. The ac is ice cold and original. I'm thinking I might have a partially clogged drain line as some water comes out upon inspection, but it doesn't seem like much. The radiator was just flushed and everything is at the proper levels. Thanks for any ideas!
da324 is offline   Reply With QuoteReply With Quote
Old 08-28-2020, 11:56 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Correct me if I'm wrong, but PLENTY of cars do this. Or are you talking about something brand new? What were your fan settings at?
You can always check the sight glass to see how much freon you got!
Old 08-29-2020, 12:47 AM #3
I've had the car for 19 years and it's never made this noise. The AC is ice frigging cold. I'm in Fl so the temp setting is max cold on the dial.
Old 08-29-2020, 12:51 AM #4
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
perhaps the evap drain is clogged. try inserting a piece of wire into the drain.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 12:56 AM #5
That's my next step. Would the floor board be wet if the evap drain line is partially clogged? Thanks!
Old 08-29-2020, 04:22 AM #6
To me it sounds like you have air trapped in your cooling system.
Or a blend door is bad and flapping around......
Old 08-29-2020, 04:34 AM #7
if the evap has overflowed, then yes, the floorboard/carpet in the RH side will be wet
Old 08-29-2020, 11:15 AM #8
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
I agree it sounds like the cooling system more than the A/C.
Your heater core is under the dash as well.
My 2cnd gens used to make that gurgling noise often.
Don't recall if my 3rd gen does. I've probably tuned that noise out.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 11:51 AM #9
It’s the sign of a bad rad cap that isn’t venting properly when cold or the rubber hose between the neck of the Rad and the expansion tank is not sealed properly and it’s sucking air instead of coolant when it cools off.
If the coolant is fillet to the top of the Rad and the expansion tank it topped off, a properly vented cooling system should have all the air purged out by the end of three drive cycles.
Some spirited driving with the heat on max temp to fully open the heat control valve on the firewall should push all that air (trapped in the heater core from his Rad flush) into the Rad where it can be pushed into the expansion tank on the next warm up cycle.
back , gurgling , line , noise , sound
under glove box noise cv470 5th gen T4Rs 33 03-08-2023 06:36 PM
Gurgling noise behind dash Morphyne 4th Gen T4Rs 14 03-18-2021 11:21 PM
Odd Noise. Glove compartment Fl_tigers 4th Gen T4Rs 2 05-04-2017 04:45 PM
noise coming from glove box mydaddycar 5th gen T4Rs 1 01-02-2011 02:32 PM
Heater makes a gurgling noise. Morania Classic T4Rs 8 05-09-2009 02:25 PM
