Old 08-29-2020, 03:20 PM #1
n517rv n517rv is offline
n517rv is on a distinguished road
Oil Change Gone Bad - Advice Needed on Stripped Oil Pan
Need some advice. My son and I were changing the oil in his 1999 Toyota 4Runner Highlander Edition. For some reason it had a 10mm oil plug and needed a 10mm gasket. I'm guessing the previous owner might have stripped it and put a threaded insert in it???
We found a 10mm copper gasket at a local auto parts store and went to torque it down to spec and now the oil plug won't tighten or un-tighten I'm thinking the oil pan needs to be replaced.
How difficult is this to do? I searched the forum and someone suggested the diff needs to come off if it's a 4 wheel drive. Does that sound right? I'm trying to figure out if this is more than we can handle from a difficulty perspective.
Thoughts?
TIA
Oil Change Gone Bad - Advice Needed on Stripped Oil Pan-4runner_16x9-jpg
n517rv is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 04:14 PM #2
Try turning it while hammering a puddy knife or thin screwdriver blade under the head. It might help you remove the plug.
Old 08-29-2020, 04:52 PM #3
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Thoughts?
TIA
The front diff is in the way of dropping the oil pan on a 4wd.
Skulking is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 05:29 PM #4
thenightman's Avatar
thenightman thenightman is offline
Real Name: keith and jenny
thenightman will become famous soon enough
So you are saying it just spins? First I would try soaking it good in pb blaster, then heat up the plug with a propane torch. The plug and the pan should heat up at different rates, unfreezing them from each other.
In the past I had a 94 Corolla with a stripped drain plug. I figured out what the next size up plug was, and tapped new threads in the bung. I then poured the used oil back through the engine, to hopefully wash out any shavings.
It didn't even leak, had that car for another 40k miles, and junked the car for different reasons.
Anyway, good luck!
Build thread
http://www.toyota-4runner.org/3rd-ge...ncemobile.html
Few dollars, and fewer sense
thenightman is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 10:03 PM #5
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
The front diff has to come out to drop the oil pan, but from what I've seen it's a relatively simple process, would just be a little tedious. I believe the CVs require a weird 30-something millimetre socket under the dust/hub cap, would be worth looking into before tackling it
The pans use a form-in-place gasket you can buy anywhere online, Toyota used it for god knows how many parts/vehicles
Very mean looking Highlander!
Old 08-30-2020, 01:14 PM #6
Outrider Outrider is offline
Outrider will become famous soon enough
Anyway, good luck!
Good tip ^^.
For tasks like this, a small butane torch comes in real handy. You can get a precise flame right where you need it, instead of heating up a general area with a big flame from a normal torch.
Something like this - but in this case, I would suggest not using the soldering tip, rather just the small (and very hot) flame:
Amazon.com: Bernz-O-Matic ST2200T Micro Flame Butane Torch Kit: Home Improvement
I use my little torch like this far more often than my big propane or Mapp gas torch.
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
Outrider is offline   Reply With QuoteReply With Quote
Old 08-30-2020, 01:20 PM #7
Anyway, good luck!
Yes, the oil plug bolt just spins. You can never tighten it or loosen it.
So I what does the PB Blaster do? I assume the torch will heat up the bolt and expand it so it might grab threads. Is that the idea?
I'll give it a try. Thanks to everyone for the advice!
Sent from my Pixel 4 XL using Tapatalk
Old 08-30-2020, 02:46 PM #8
Most of the advice given (Heat and PB blaster) is really only useful for when you have a seized bolt or nut which you don't have. @19963.4lsr5 was right in his first post. Use a flat bladed screw driver or something similar. Get your wrench or socket on the bolt and while loosening use the screwdriver blade underneath the flange on the bolt head to apply gentle force downward to help the bolt come out. You aren't trying to pry the bolt out with the screwdriver, just encourage it a little bit to come out since it doesn't have enough thread engagement to back itself out without help.
10mm , gasket , needed , oil , plug
Special tools needed for the TB/WP/etc change? ShooterMcGavin 3rd gen T4Rs 13 05-28-2014 01:47 PM
Engine change advice needed HELP! 1oldyota 3rd gen T4Rs 2 11-13-2012 10:39 PM
E-Locker Gear Change Help needed 4RUNNERTMAN 3rd gen T4Rs 7 05-28-2012 12:09 PM
Auto trans fluid change advice needed z28forlife 3rd gen T4Rs 8 02-12-2012 12:44 PM
A little fluid change advice needed. Blanco 3rd gen T4Rs 10 12-25-2011 10:53 AM
