Old 09-26-2021, 12:29 AM #1
OffroadTwin OffroadTwin is offline
Real Name: Alec
OffroadTwin is on a distinguished road
Real Name: Alec
Key in ignition is completely loose in all positions except “off”
Hello all,
I’ve returned to the forum now that I’m on my second 4runner! Picked up a 01 limited 4x4 with 220k from the original owner. I like it but it has a few small issues. One thing that just started yesterday- the key feels normal when inserting the key. Then when I go to turn the key clockwise for accessory/run/start the key becomes COMPLETELY loose and is so loose it could fall out going uphill, there is nothing holding it in. It can be removed and places back in without issue. Then when I shut off the car/return the key to off position there is the normal grip/pressure that holds the key secure.
Any ideas? Happens with both my keys, and it was working 100% fine then randomly one day was 100% loose. I found tons of threads for stuck keys but haven’t seen a single thread for loose keys.
OffroadTwin is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 12:56 AM #2
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough TheSaturnV will become famous soon enough
Mine does it too. You can easily pull it out of the IGN switch while it's running.
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 09:35 AM #3
spartacus's Avatar
spartacus's Avatar
Lightbulb
A new key or a new ign cylinder rekeyed to your existing might be the solution.
Old 09-26-2021, 10:08 AM #4
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
The ignition key lock/tumbler most often wears out because many put all their keys on one keyring.
Three pounds of keys hanging down, swinging back and forth wears it out.
Each of my vehicles has ignition, possibly door, gate and house key. All my other keys are on other keyring(s).
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 02:23 PM #5
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
My problem was fixed by getting a new key cut from dealer and removing some wafers (specifically the split ones). Make sure you take your ID with you, bill of any sort which says your address, and title of ownership so you can prove it's yours. I also had heavy stuff on my key which worsened the problem to the point where I couldn't turn the key and was stranded.
2000 4Runner Limited 4x4 V6
Old 09-28-2021, 03:15 PM #6
Real Name: Alec
Real Name: Alec
UPDATE-
Got a new key from the dealer, it holds secure! However, my 4runner won’t start!! It just cranks endlessly but won’t actually start with the new key. The second I plop in my old loose key it starts in 1 second. Any ideas?
Old 09-28-2021, 03:29 PM #7
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Originally Posted by OffroadTwin View Post
UPDATE-
Gotta get the chip in the key programmed. I believe there is a way to do it without the dealer but I don’t remember the process (I think it’s similar to programming a new fob). Dealer should be able to do it though.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-28-2021, 03:50 PM #8
Real Name: Alec
Real Name: Alec
Turns out they gave me the non-chip key so they’re ordering the correct one then I’ll have it programmed. Should be all set thanks for the fast replies everyone!
Old 09-28-2021, 05:11 PM #9
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Lets hope you have the RIGHT key currently. There are 2 ways a key can be programmed, one will allow for other keys to be programmed and the other won't. Look at that blinking red "Security" light next to the rear window switch... if you put the key in and that goes out IMMEDIATELY, you have the right key and no worries. If it blinks for another second or two (might go solid, I forget) ~ you're SOL.... sorry. The "fix" is a $1000 body ECU from Toyota (though my dealer shows it at $675 for online order), or lucking into the Right locksmith with the Right tools to reflash the chip on the board.
It can be DIY, but you'll have to search for that info yourself (searching is the easiest part, it gets substantially more complicated from there).
Brian. is offline   Reply With QuoteReply With Quote
Old 09-28-2021, 05:49 PM #10
T4topher's Avatar
T4topher's Avatar
Only got one chip key from PO when I purchased mine.. gunna check this when I get home, thanks for the info lol..
100% , key , keys , loose , normal
Moonroof, two positions ? Justin.Geer81 5th gen T4Rs 3 05-02-2020 01:06 AM
Suggestions on light bars with adjustable mount positions benjamin247 3rd gen T4Rs 1 02-23-2020 11:32 PM
Intermediate Positions on AC Dial Kae006 General Discussions 6 12-14-2017 12:33 PM
D vs S5 shift positions rickl 5th gen T4Rs 3 09-08-2014 07:55 PM
Weird Side-View Mirror Positions angrydog 5th gen T4Rs 2 07-13-2010 09:34 PM
