Old 08-31-2020, 07:15 PM #1
CT135 CT135 is offline
CT135 will become famous soon enough
Need new bushings or steering rack?
Symptoms: 4runner pulls to the right. Now crazy bad, but enough to be annoying. I took it into firestone for an alignment and they told me it was my steering rack. They said it needs replaced, and strongly suggest bushings also.
My rack is not leaking or anything. I have read on there that bushings are related to loose/sloppy steering but would it impact pulling to one size? Should I try bushings first? Or just replace the rack and pinion all together?
*i am going to be taking the front end apart anyways to re do my oil pan gasket?l, so I’d just add that to my project and make it a longer day. I just don’t really feel like spending $500 if I don’t have to lol
97 Limited, 5100’s, OME 883/891, Built Right UCA, Custom Sliders, coastal off-road front bumper, 4x innovations rear bumper(custom built swing out), 4.88 gears, Circuit Offroad 17x8.5 wheels, Kenda Klever RT 35x10.5r17
CT135 is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 08:30 PM #2
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
I did the whole steering rack restoration with new bushings and tie rods. It's still a 200k POS. Just replace the whole rack and check that problem off the list. It comes with new ITRE's too.
Old 08-31-2020, 08:55 PM #3
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
If you do decide to replace your steering rack, you probably want to grab the "Gear Assembly Insulator" part number 45517-35010 separately as it does not come with the rack. It's the one bushing that is considered separate from the rack, and while you can install it later if you need to, it's easier to just do it with the rack. It is included in both the energy suspension and whiteline kits if you decide to just replace your bushings with aftermarket bushings.
Skulking is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 09:25 PM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Mine moved 3/4" side to side before this kit:
Amazon.com: TRW JBU1005 Premium Rack and Pinion Mount Bushing: Automotive
Solid as a rock now.....
Old 08-31-2020, 10:25 PM #5
sthomps30 sthomps30 is offline
sthomps30 is on a distinguished road
Buchings
mine was sloppy even after realign. Most pronounced between 55-70. Just replaced bushings with poly & made world of difference. YMMV
2002 runner SR5 Sport, lift done before I got it (new to this & unsure how to check), sound deadened & screwed by an LED instrument cluster upgrade gone awry
sthomps30 is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 02:08 AM #6
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Hopefully, you don't find out like I did when replacing the rack that the higher pressure hose assembly is shot b/c it's a $400 part from Toyota
Doc3g is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 10:48 PM #7
T4R2014's Avatar
T4R2014's Avatar
Is that a rubber bushing? My energy suspension poly bushings squeak like a POS on these NYC roads. Avoid poly at all costs.
Old 09-02-2020, 12:41 AM #8
Dude that is not what I wanted to hear! Lol
Old 09-02-2020, 12:44 AM #9
I didn’t know the oem rack came with ITRE’s. That’s like $300 right there. Not a bad deal. Considering doing the outer TRE’s also and basically have a brand new steering system.
Old 09-02-2020, 01:09 AM #10
HiLife HiLife is offline
If your rack is not leaking, doesn't make any wierd noises moving the rack back and forth, the rack should be still good. I would check the itr and otr for looseness/slop. And replace the bushings and go from there.
My experience with worn rack bushings was a death wish driving anything above 55mph. Truck tracked left and right very erratically. 55 and below mph was manageable. New rack bushings fixed the tracking issues for me.
Old 09-02-2020, 03:21 AM #11
look171 look171 is offline
look171 is on a distinguished road
I have no experience with 3gen and only can compare to my 5 gen. Tonight was the first time we drove it after all suspension including coils and rubber parts had been replace under there. The steering doesn't have a solid feel to it. I feel a bit of jerkiness or a tiny bit of sloppiness or play at the wheel. No vibration at 70 mph. This is my kids 4 runner. He will be 16 next year so we spent the summer working on it. How do I know if a steering rack is needed? No leaks, but I see a bit of movement under the car when he turns the steering wheel back and forth. My 5 gen's steering is rock solid with no play.
look171 is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 09:20 AM #12
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Get a second opinion. Especially if they are not leaking.
I replaced both lower control arms and sway bars on 2005 SR5 with 150,000 miles on my mechanics advice, I bought the "exact fit" parts on Amazon.com and they were not expensive.
Amazon.com: 2 New Front Lower Control Arms With Ball Joints Left Right Compatible With 2003-2009 Toyota 4Runner; 2007-2009 FJ Cruise; Lexus GX470 Replaces Dorman 521-433 521-434: Automotive
Amazon.com: MOOG Chassis Products K90683 Stabilizer Bar Link Kit: Automotive
Captsolo is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 11:07 AM #13
Those are 4th gen parts not 3rd gen.
Old 09-02-2020, 11:17 AM #14
My bad steering was worn lower control arm bushings. It drives like a dream now.
It would randomly just decided to track left or right with the steering held strait ahead. I had zero up and down play on my rack ends and when I would just start to turn the wheel my tires moved. So, I put my finger on the real lower drivers side bushing and had Kendra turn the wheel and I could see and feel the bushing deflect almost 1/8”.
Old 09-02-2020, 12:06 PM #15
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If your rack isn't leaking, I wouldn't jump right into replacing the steering rack because it's quite pricey. An OEM rack that comes with inner new inner tie rods will run you around $500.
Get under the rig and have someone you trust not to run you over get in the driver seat, start the rig and turn the wheels back and forth while you're staring at the steering rack. If you see gross movement left to right, you're bushings are toast and it's time to replace them. But, I'm not not sold on the fact worn steering rack bushings are causing your pulling issue. I would also suspect worn lower control arm bushings like somebody mentioned.
I would advise you to not follow the suggestion of buying aftermarket control arms. People have shared horror stories of failures with these cheaper control arms. Even the OEM LCAs can fail from lots of abuse from hard 4wheeling so inferior LCAs is a bad idea. Same goes for aftermarket steering racks. Quite often, the aftermarket steering racks fail quickly forcing you to either pay for the labor to replace it again or you yourself has to get under the rig to replace it. A Lifetime Warranty might end up being a Lifetime of Misery for you having to repeat the same job over and over again. Buy OEM for important components like this because in the long run it's the smart choice.
This video shows another technique of removing the LCA bushings with a hydraulic press and also addresses a common issue of finding the cam adjuster sleeves rusted and stuck in the bushings.
bushings , don’t , end , rack , steering
Has anyone had steering rack bushings go bad? Seymore Butts 4th Gen T4Rs 12 06-07-2019 06:00 AM
'98 4Runner Steering Issues: New Rack or ITRE's and Rack Bushings? TheFriZ 3rd gen T4Rs 23 04-25-2019 12:35 AM
Steering rack bushings? dkyleb 4th Gen T4Rs 4 03-01-2017 11:34 AM
Steering Rack Bushings for 4th Gen luke87gt 4th Gen T4Rs 0 11-21-2016 04:02 PM
Help with Steering Rack Bushings satek 3rd gen T4Rs 4 12-29-2012 02:21 AM
