Old 08-31-2020, 09:12 PM #1
hawkcharmer's Avatar
hawkcharmer hawkcharmer is offline
hawkcharmer is on a distinguished road
Cut seized cam bolts lower control arm question?
My lower cam bolt sleeves are seized! I managed to remove all 4 screws but the sleeves are seized!
I plan on cutting them off and replacing with new lower control arms from toyota and all new cam bolts.
Question is...
On installation, can I reverse the new cam bolt direction that the steering rack blocks? I don't have to alter the rack if I cut the bolts because it drops straight down. But, If I install the new bolts in the previous direction, I would need to loosen the rack to get the new bolt in.
It would be much easier to not move the rack. Each bolt is a nightmare in the rust belt.
Thank you
1999 4Runner SR5, 3.4L 5VZ-FE V6 | Tundra/890 coils | 5100 Bilsteins all around l 199mm Tundra brake upgrade | 265/75/16 Falken Wildpeak AT3 tires | ARB Bull Bar
hawkcharmer is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 06:48 AM #2
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Won't work, Nut side is tall/long interferes with rack.
Old 09-01-2020, 08:17 AM #3
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
You can put in the SPC cam bolts. They are made so you don't have to remove the steering rack. I put them in my 97 and they work fine
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 09:04 AM #4
Real Name: Mark
Real Name: Mark
Glad you had good luck with them. Flats in washers rounded off second aligment, much prefer OE on this part.
Old 09-01-2020, 10:59 AM #5
jack.hanks02 jack.hanks02 is offline
jack.hanks02 is on a distinguished road
I'm getting ready to cut my surely seized cam bolts out as well, so I will follow along with your progress. You could leave a comment on Timmy's YouTube video and someone might reply.
I am really dreading messing with the steering rack. Seen horror stories of bolts shearing off.
Sent from my PH-1 using Tapatalk
jack.hanks02 is offline   Reply With QuoteReply With Quote
bolt , bolts , cam , lower , rack
OEM lower Control arms and cam Bolts part #s Billynath1988 4th Gen T4Rs 7 01-06-2020 10:14 AM
Found 3 of 4 lower control arm bolts loose after alignment... Jin 5th gen T4Rs 3 10-24-2017 02:59 PM
Sheared bolts and seized bolts. Need help. mavrick1903 4th Gen T4Rs 8 07-18-2017 01:33 PM
Removed Two Lower Control Arms Bolts, Can't Get Back Together Riflman 4th Gen T4Rs 8 11-01-2016 07:19 PM
Lowering Lower Control Arm WITHOUT loosening body bolts? DaveK22 4th Gen T4Rs 4 09-30-2013 10:57 AM
