Old 09-02-2020, 10:22 PM #16
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Originally Posted by billyblunk3 View Post
I ordered brushes from Toyota. They were 35 bucks after tax. Will be here Friday.
She sat for a while so I cleaned all the connections when I put a battery in it a few months back.
Gave the alternator a few love taps and it’s charging again. Will be replacing brushes this weekend
I had the same symptoms one time. Put in new brushes and then put another 200,000 km on the corolla. The tap to fix is an indication it’s brushes making intermittent contact as they are now too short in length.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 07:47 AM #17
billyblunk3 billyblunk3 is offline
billyblunk3 is on a distinguished road
Yeah that’s what I’m going with. They show up tomorrow. Can’t wait.
billyblunk3 is offline   Reply With QuoteReply With Quote
Old 09-04-2020, 02:40 AM #18
negusm negusm is offline
negusm will become famous soon enough
Originally Posted by gamefreakgc View Post
Visual inspection of connections are not enough. Ask me how I know. Give the battery terminals and the ground strap from battery to fender a good cleaning.
Not just that, but disconnect the cables and bend them around. Wiggle/bend the ends a bit. They should take some abuse without making crackling noises.
I had a bad time with my negative cable until I cut 12" off from it and soldered on a new section. 12" was just corroded inside but you couldn't see it just by looking at it. I replaced it with the old-school lead terminal. Far superior than what Toyota used. Their terminals will crack over time and it leads to corrosion which starts moving internally up the cable.
Got the brush set...but have 260k on her and the alt still runs ok. Debating whether to do it.
2002 4Runner 4WD SR5 - Original Owner
negusm is offline   Reply With QuoteReply With Quote
Old 09-04-2020, 11:38 AM #19
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
At 260K, you don't have much life left. Mine died at 225K. It's an easy repair, just pop out the alt and swap the brushes. Very little work needed to remove it all.
326WHP 347TQ
Old 09-04-2020, 01:07 PM #20
And it’s swapped.
Old 09-04-2020, 03:02 PM #21
And it’s swapped.
The 80a three year old reman from CarQuest stopped charging. Wacking it with a hammer fixed it so I ordered brushes from the dealer and replaced them. The brush assembly I pulled had brushes that were barely 1/8” long. I’m sure they were either the cheep 6 dollar brushes, or the Alt had a different failure like a voltage regulator.
Reman stuff is not a full rebuild. They only replace what’s broken imo.
Old 09-04-2020, 04:17 PM #22
Actually the other way around?
Rebuilt Engines vs. Remanufactured Engines, Used & Crate
But yeah, they use the terms to confuse us I think. They just replace what is broken is all.
Old 09-04-2020, 04:26 PM #23
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
And it’s swapped.
But did it fix your charging issue? Inquiring minds want to know. I also want to know if you found the video helpful.
Old 09-04-2020, 09:46 PM #24
Video was helpful for the placement. Drove it 100 miles to make sure and she’s back to normal now. I wanted to give it a full test before reporting back.
Old 09-04-2020, 10:07 PM #25
ambush ambush is offline
ambush will become famous soon enough
And still charge you and insane price + a core (if you dont have an old one)!!
For me, OEM period. Even if it is at the wrecking yard, Denso has never let me down.
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
Old 09-04-2020, 10:14 PM #26
Say what you want, I’ve had plenty of rebuilds that had problems. Which is why I do shit by myself or I take my problem to someone I trust. Try replacing the axle seals on a Dodge Ram front axle. Or ball joints. It’s not fun.
Old 09-05-2020, 08:51 AM #27
NoVA_T4R NoVA_T4R is offline
NoVA_T4R is on a distinguished road
I will second the OEM quality. Original Denso went out around ~190k miles. Toyota dealership couldn't get a new alternator until next day, which was too long.
Local auto shop could put in a Duralast same day. It lasted about 10 months before the batt light kept coming on and ignition was misfiring.
Took it in, they swapped it out with another Duralast. That one lasted almost a year and started having problems. Local shop replaced it again under warranty.
I bought an OEM alt from a Toyota dealership that does internet sales as a backup in case the 3rd Duralast failed.
After about 15 months it failed too. Even though it had a lifetime warranty, the local shop refuses to replace it again. I had them put in my ordered OEM and order a replacement Duralast which I took, uninstalled as a spare.
Given how important it is to the operation of the vehicle, keeping track of when they are relatively inexpensive on Camelback, Toyota of Dallas, or other stores that do internet sales of OEM parts and picking one up is worth considering.
The "kaboom" of late detonation of misfires is not a pleasant experience.
Sent from my Pixel 3a using Tapatalk
NoVA_T4R is offline   Reply With QuoteReply With Quote
14.1v , bye , light , showing , started
Alternator? colby4runner Maintenance/Detailing 5 04-19-2021 01:41 PM
Alternator Help? Buckeye77 5th gen T4Rs 1 03-24-2014 09:09 PM
95 alternator kit? kobrak Classic T4Rs 1 01-28-2011 10:48 PM
alternator help riceandpho 3rd gen T4Rs 1 10-05-2006 09:26 PM
