Old 09-04-2020, 11:05 AM #1
@jhcamacho's Avatar
@jhcamacho @jhcamacho is offline
Real Name: Joey
@jhcamacho is on a distinguished road
@jhcamacho's Avatar
Real Name: Joey
Radiator Fitting for Transmission fluid corroded off.
Radiator fitting that has tranny fluid broke off.
Had a small leak, gave a little wiggle and the fitting popped off. I’m going to drop it at the Radiator shop. Any advice would be greatly appreciated.
Cheers, Joey
Radiator Fitting for Transmission fluid corroded off.-5489eaf0-15a7-4707-94e2-aad5f5994d27-jpg
@jhcamacho is offline   Reply With QuoteReply With Quote
Old 09-04-2020, 11:43 AM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
My advice is to replace the radiator. If the radiator is old enough that that fitting broke, it's had a good life and it is time to let go and get a new radiator.
Skulking is offline   Reply With QuoteReply With Quote
Old 09-04-2020, 11:57 AM #3
@jhcamacho's Avatar
Real Name: Joey
@jhcamacho's Avatar
Real Name: Joey
That’s the plan- OEM replacement maybe a tranny cooler in the future. I was just hooking up the boat for a day of bass fishing.
Old 09-04-2020, 11:58 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Cheers, Joey
Time to replace the radiator. DO NOT ATTEMPT TO REPAIR THAT If it broke off there then it is likely the internal cooler is about to rupture and then you'll have the dreaded pink milkshake to deal with.
Old 09-04-2020, 08:21 PM #5
@jhcamacho's Avatar
Real Name: Joey
@jhcamacho's Avatar
Real Name: Joey
Got it fixed today along with new hoses and a thermostat.
Thanks All
2000 Limited
Kings all the way around
Method Wheels
Toyo A/Ts
Old 09-05-2020, 10:43 AM #6
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Thanks All
Well done!
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
advice , fitting , fluid , greatly , radiator
Which hose on the radiator is transmission fluid inbound" cdg11343 3rd gen T4Rs 2 02-28-2020 11:03 PM
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Need help finding transmission cooler fitting Brett B 4th Gen T4Rs 5 06-12-2017 09:10 PM
How much Transmission Fluid do you lose changing the Radiator pconner748 4th Gen T4Rs 13 04-21-2016 08:54 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
