Old 09-02-2020, 07:04 AM #1
nail bender nail bender is offline
nail bender is on a distinguished road
TRAC VSC and ABS lights on
how do I troubleshoot this issue and get the lights to go off? thanks for any help.
nail bender is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 11:33 AM #2
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Alternate Search for T4R - 3rd Gen Section
Old 09-02-2020, 12:01 PM #3
Whakeen Whakeen is offline
Whakeen is on a distinguished road
Buy or borrow an OBD II scanner and get the error code. Once you have the code use the search function linked above. If you still can't get to the bottom of it post the error code on here. Good luck.
Whakeen is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 02:17 PM #4
spartacus's Avatar
spartacus's Avatar
I'm the check engine light also on? Have you replaced the cluster lights 20th leds if so that could throw the voltage off and cause the issue. The VSC module, abs sensor cleaning might help. some folks have just disabled the VSC system.
Old 09-02-2020, 04:23 PM #5
Real Name: Mark
Real Name: Mark
Where I started a while back on a 01.
Speedometer/Odometer Not Working + Related Warning Lights (P0500) - Toyota 4Runner Forum - Largest 4Runner Forum
Old 09-03-2020, 10:02 PM #6
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
pull the rear axle sensors and see if there gear oil on them. This can cause those lights to go off.
plcfcng is offline   Reply With QuoteReply With Quote
Old 09-05-2020, 11:10 AM #7
biggestmexi biggestmexi is offline
biggestmexi is on a distinguished road
First, if there is no engine light, an OBDII code reader will not do anything.
Second, you will need to check your ABS codes, which is easy.
  • Find the "DIAGNOSTICS" connector that's on the drivers side of the engine, on the high edge of the intake plenum.
  • In the lower left, you'll find a small plug that pulls out. That's a "shorting pin", pull it.
  • Now use a piece of wire to jumper from E1 to Tc.
  • Go into the truck and turn the key forward.
  • Watch and count the blinks of the (ABS) light.
With the light blinking it will blink a certain number of times and then short pause then blink again. This will give you the 2 digit code. Wait for the code twice as you might have more than one code.
Then you can start from there.
biggestmexi is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 10:13 AM #8
Thanks I think this will help. the check engine light is not on just the others stated in my first post
Old 09-06-2020, 10:45 PM #9
Yeah, the ABS system doesn't post codes to where you would find a normal engine trouble code. So, a regular OBDII reader won't work. The method above is super easy.
I just recently had an issue like this and found it through the ABS codes.
My issue was the rear pass. shock top was sheared off and hit the cable for the speed sensor and ripped it.
Old 09-07-2020, 08:52 PM #10
losso losso is offline
losso is on a distinguished road
I had the same issue and my problem was the third brake light was out. Check that. Good luck
losso is offline   Reply With QuoteReply With Quote
Old 09-08-2020, 09:24 PM #11
is there somewhere I can find what the code means. when the jumper is in place the abs light blinks 3 pause 2
Old 09-08-2020, 09:35 PM #12
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
A few posts above you there is a post with a list of all of the codes. Based on your description of the flashes, it sounds like code 32 which according to that list is Left Front Wheel Speed Sensor Signal Malfunction.
Skulking is offline   Reply With QuoteReply With Quote
Old 09-08-2020, 09:43 PM #13
I found what the codes meant online. I had replaced the left front wheel speed sensor and as I new it was bad. caught the wires when removing the oil filter and pulled them out of the plastic connector. left front wheel speed sensor code was what came up. I did not know I needed to clear the code to get the lights to go off. now that I have cleared them they are all off. thanks to all for your help
Old 09-09-2020, 11:29 AM #14
nail bender, glad you got it sorted out and my apologies for posting incorrect guidance. I hastily read your post and assumed it was a similar situation to mine where I had the VSC and TRAC lights on as well as the CEL.
And thanks to biggestmexi as I learned something today about the ABS codes! I've been a motorcycle guy for about 25 years so I'm still figuring out auto troubles as they come up.
Old 09-09-2020, 10:03 PM #15
No problem and glad to help. I recently had to look up all this info and there wasn't an easy place to find it all together so I put it here.
issue , lights , trac , troubleshoot , vsc
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 120 11-22-2023 07:11 PM
2003 4Runner- VSC Trac/ Trac Off Lights Only coolvman83 Problems & Warranty Issues 13 10-30-2019 11:05 AM
VSC TRAC and TRAC OFF Lights Stay On danielatx Problems & Warranty Issues 4 12-11-2014 12:50 PM
Check engine light vsc trac & trac off lights come on piptraderfx New Members 5 03-14-2014 07:47 AM
2006 V8 2WD CEL, VSC TRAC, TRAC lights all on... T4RPILOT 4th Gen T4Rs 4 10-10-2012 12:29 PM
