Old 09-02-2020, 09:23 AM #1
FrogginAround's Avatar
FrogginAround FrogginAround is offline
FrogginAround is on a distinguished road
Coolant Temp
I just recently got an Ultragauge and it was reading an average of 203 while rolling down the highway on a road trip. Is this normal? The truck has 295k on it. I was afraid the head gasket was going to fail 800 miles from home.
96 Stellar Blue Pearl Limited. 5VZ-FE. 290k. Auto. E-locker. Small lift.
FrogginAround is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 09:55 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That's a little high, but it's not overheating. Most folks see 188-192 degrees. Common reasons for running warmer than that are old/clogged radiator, thermostat with the jiggle valve at 12 instead of 6, or old coolant. An aftermarket bumper that restricts too much air flow can also cause that, but it usually has to cover quite a bit to be an issue. A few people have reported temps in the range you're seeing when the fan clutch is just starting to fail as well.
EDIT: Forgot to include failing radiator cap as well.
Old 09-02-2020, 10:03 AM #3
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
You're running too hot for a 5VZFE, but you're not going to hurt anything in the near term with those temps. Needs addressing though.
Inspect items in order from easiest to most intensive:
1- Radiator cap. If not keeping pressure, you can heat up.
1a- Inspect coolant level and condition. Is it low? is it murky? Is your overflow tank empty?
1b- Inspect radiator itself. Is the top of it coppery brown colored? Any cracks anywhere? Have you ever replaced the Rad? If yes to any of these, time for a radiator and coolant flush with Toyota Red coolant.
2- Fan Clutch- Test it. Search Youtube for Timmy Toolman fan clutch test to see how.
3- It could be your Thermostat jiggle valve in the wrong position. You'll have to drain the coolant from the radiator, remove the lower hose, and remove the thermostat housing to see. It's not too hard. the little wiggly valve needs to be at the BOTTOM 6 o'clock position, not 12 o'clock as many techs mistakenly install it wrong.
4- If all of the above checks out, when's the last time the water pump was replaced?
Just a starter list!
In my case, I was running 209-211 on the highway. My jiggle valve was the culprit. After putting it at 6 o'clock, I never go over 194, even in extreme duty.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 10:39 AM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
With my 98 4runner with an aftermarket bumper and winch on the front, I've got restricted air flow through the cooling fins of the radiator and that's one reason why my 98 runs hotter than my 2000. Another reason is all the extra weight my 98 is carrying all the time. Bumpers, full compliment of heavy duty skids and a steel roof rack. The thing is a beast so the engine struggles which causes higher engine temps. So, with the California hot weather we're having right now, I saw high 190's and low 200's driving on a recent trip.
My guess is your thermostat jiggle valve isn't at the 6 o'clock position. But, first check the condition of your radiator cap. They are known to fall apart and the spring and plastic cover end up inside the radiator. The result is they don't keep proper pressure on the cooling system anymore.
I probably wouldn't expect a problem with your fan clutch because you're overheating while driving down the freeway. A dead give-away your fan clutch is the culprit is when you're overheating while in stop and go traffic. When you're at a standstill or driving very slow, the fan clutch is doing the bulk of the work to pull air through the cooling fins of your radiator.
This video might help you out:
Old 09-02-2020, 11:23 AM #5
19963.4lsr5 19963.4lsr5 is online now
At your milage I’d replace the rad if it’s never been replaced. And all three 4Runners had a broken rad cap.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 09-02-2020, 01:44 PM #6
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Make sure the jiggle valve is at 6 as others have stated.
New radiator cap if original.
Newness of the water pump and fan clutch?
Make sure to burp the snot out of the cooling system when replacing coolant. I have had to burp my cooling system for up to 20 minutes on an incline, then shut it off and naturally let the coolant cool down. Now between 186 and 190f in the sweltering South with the heat index at 110f and AC on.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 02:54 PM #7
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
In case its gone offroad where tallish grass is involved, after removing front skidpan, look up between a/c condensor and radiator, clean out any grass or other debris between the two for obvious reasons. Luck.
Old 09-02-2020, 06:56 PM #8
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
It helps to include where you live and if you were running the A/C. I know how hot it can get in Chico and I'm guessing you were running the A/C system so that's a totally normal temperature to see. The vehicle will fluctuate from the 180's in the winter months to a max of 210 in the summer (100+ weather with A/C on in stop and go driving) which is all considered normal.
Note that the gauge won't budge an inch between 180 and 210 degrees. Only once you start to push 220 or higher will the gauge creep towards the red. Around 250 degrees you'll hit the redline and experience cooling system failure.
326WHP 347TQ
Old 09-02-2020, 08:25 PM #9
The water pump was replaced less than 2 years ago.
The radiator just before that. I had the coolant flushed and replaced while this was happening during my trip. I did not use Toyota red. I was not running the ac. In fact, I ran the heater which typically brought it down between 194-199. When I came to a stop it began to spike up to 215, but cooled back down right as I got moving. I'm thinking i will look at the thermostat position and maybe try a water wetter. Thanks for all the replies everyone. You all stay safe out there.
Old 09-03-2020, 08:39 AM #10
It's probably your jiggle valve, given this info. I'd start there. Free and easy fix
Old 09-03-2020, 09:45 AM #11
Real Name: Patrick
Real Name: Patrick
That to me sounds like fan clutch starting to fail in combination with radiator cap or thermostat jiggle valve.
Old 09-03-2020, 11:33 AM #12
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
I agree.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 02:51 PM #13
Real Name: Jerod
Real Name: Jerod
I think you are on the right track then. 215 with A/C off and heater on is too hot. Imagine if your A/C was on, it'd be 225 easy.
326WHP 347TQ
Old 05-01-2022, 03:39 PM #14
hikinfool hikinfool is offline
hikinfool is on a distinguished road
2004 4runner coolant temperature sensor
My apologies if this is the wrong place to ask, but I can't figure out the threads... I am in need of changing the coolant temperature sensor on my 4x4 V6 4runner. I (think) i've found it at back center of motor on top, but there is a hose preventing me from getting my socket on it. What is this hose, and can it be moved or removed to gain access to the coolant temperature sensor?
Thanks in advance!
hikinfool is offline   Reply With QuoteReply With Quote
Old 05-01-2022, 03:45 PM #15
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Thanks in advance!
If it's a 2004 then you have a 4th gen. You want to ask that question over in the 4th gen section.
Skulking is offline   Reply With QuoteReply With Quote
295k , afraid , head , normal , truck
Coolant temp while towing. JoshuaHufford 4th Gen T4Rs 10 09-12-2019 08:04 AM
coolant temp sensor SAYWHAT 3rd gen T4Rs 31 08-30-2018 07:44 PM
Coolant Temp Switch on the 3.0 Adumb Classic T4Rs 0 11-10-2016 01:35 AM
Water/coolant temp T4R-DDOGG 3rd gen T4Rs 20 09-05-2015 07:19 PM
Coolant temp - the answer? PoshSnoop 3rd gen T4Rs 3 06-07-2015 02:02 AM
