Originally Posted by stever1000
How do you get the wire from the tailgate to the license plate?
There's a decent post here. I am not fully sure on the write up but the pics are good. You remove that chrome cover and the back plastic panel on the tailgate. Then follow up through the trimmings to the rubber housing on top. Use a wire hanger to wring it through. The RCA cable connectors are really big. I drilled a small hole to wriggle my RCA connectors through. U read that you can cut the RCA wires and just solder them back together too since they are wrapped individually inside and you can shrink wrap them back.
I have no idea what Salman above was referring to about the camera end though: At camera end; got power from reverse tail light. The Yellow detection wire was attached to red wire.
-There should be a black, red, and yellow RCA with red wire attached. I saw a video where the red wire from the yellow RCA was spliced to the black ground wire and attached to one of those plug connectors and grounded to the vehicle body. The red wire (power) was then routed back to the headlight or horn fuse with an add a circuit.
