Old 09-02-2020, 10:45 PM #1
HappyHooligan's Avatar
HappyHooligan HappyHooligan is offline
HappyHooligan is on a distinguished road
Hella 4000 wiring
so I'm hooking up my Hella 4000's. Halogen version. I bought the wiring kit and thought I hooked everything up well. Brown wire off the lights to the body, red to power, long brown to the body and nothing? I think maybe my grounds need ground down to get to pure bare metal.
Anyone have some pics where they attached everything on theirs? Also trying to figure out how to hook up a different switch but first I need the switch it came with to work before I do that.
_________________
2000 Sport
2882/5100 906/5100
HappyHooligan is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 11:14 PM #2
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I had a Hella harness that was put together wrong. They put the wrong colors in the wrong holes in the relay plug. Something to think about.
You do know you need a main power source for the lights, usually the battery positive, and one for the relay trigger coil, often the parking light circuit.
Can you sketch your wiring diagram? It's not so much where you attach the wires as how they work together.
My Backyard Frame Swap
Old 09-03-2020, 12:24 AM #3
ah... didn't see the relay wire. That's probably it. Is it that really long green one?
_________________
2000 Sport
2882/5100 906/5100
Old 09-03-2020, 01:35 AM #4
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
Off topic a bit, but where are you mounting those 4000’s? They’re an all metal housing and super heavy from what I remember when I had some about 13 or 14 years ago. Unless it’s to a very rigid mount like an offroad bumper or a tube style light bar that mounts to the frame, they’re going to wobble like crazy.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 10:56 AM #5
Going on my ARB Bull Bumper. Plenty strong for them. And yes, they're beasts!
_________________
2000 Sport
2882/5100 906/5100
Old 09-03-2020, 10:56 AM #6
so this green wire, does it go to my headlights then? since mine is a 2000 and has daytime lights they're always on. Anyone know?
_________________
2000 Sport
2882/5100 906/5100
Old 09-03-2020, 12:02 PM #7
TheDurk's Avatar
TheDurk's Avatar
You need to show me your wiring diagram for the lights and then I can tell you where to connect the wires on the truck.
Old 09-03-2020, 12:21 PM #8
upload image
_________________
2000 Sport
2882/5100 906/5100
Old 09-03-2020, 11:33 PM #9
TheDurk's Avatar
TheDurk's Avatar
Ok. First, that is exactly the harness I had from Hella that was defective and gave me a vampire draw that took me months to figure out. So first verify that the brown wire is connected to Terminal 85 and the green wire to Terminal 86 on the relay. If those are correct, it doesn't matter if the red and black are reversed.
Assuming your harness is correct, yes, the green wire is the connection to relay trigger power. I recommend connecting it to the hot wire to the parking lights. This let's you use the aux lights alone, or with highs or lows but turns them off in the daytime or when parked.
I am not at my computer so I can't check what color that wire is, but it is not the white-black one at any parking light. I'll add the correct color later. Then brown is ground, red is battery positive and black is also ground.
The red wire needs a fuse and I don't see any. I hope there is one somewhere. Is there?
Good luck.
EDIT: On a 2000, all those parking light hot wires are green.
Old 09-04-2020, 04:21 PM #10
Good luck.
Thanks. I found the green wire and will connect it when I get back on it. I did touch the green on the harness to the positive and the lights turned on. They wouldn't turn on without the engine running. I guess they draw too much juice!
_________________
2000 Sport
2882/5100 906/5100
body , brown , hella , switch , wiring
NPA: NEW! Rallye 4000 X LED from HELLA TotalAutomotiveLV Off-Roading 0 06-09-2015 06:56 PM
Hella Rallye 4000 wiring JeepKiller 3rd gen T4Rs 3 11-01-2014 05:41 PM
Hella Rallye 4000 Driving Lights and Hella Harness IdriveaFOURrunner For Sale: Non-T4R Items 0 10-26-2014 06:26 PM
Westin Bar and Hella 4000 Deaner9505 Engines / Suspension / Wheels / Tires / Audio / Accessories 10 10-18-2007 09:38 AM
Hella Rallye 4000 AlexJet Engines / Suspension / Wheels / Tires / Audio / Accessories 0 09-15-2005 11:51 AM
