Old 09-12-2020, 09:26 AM #16
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Originally Posted by jkoni426 View Post
Ok I think I fixed mine and it was stupid easy... apparently the torque on the speed sensor bolt is pretty important. I didn't torque these when I reinstalled them, and decided to go out and torque them to spec of 71-in pounds. The driver side was close but the passenger was fairly loose. After torquing no more abs engagement when coming to a stop at slow speed.
OK, I'll give that a try. I need to figure out where they are, if you have a pic or diagram, would you mind dropping it here?
Relatedly, I took it for an alignment on Thursday and when they test drove it they noticed the abs trying to engage at slow speed stops and said that at a quick glance, it appeared that the abs wasn't communicating with the abs unit, which they thought was odd, but the shop was swamped and didn't have time to investigate it any further that day.
Doc3g is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 10:34 PM #17
biggestmexi biggestmexi is offline
biggestmexi is on a distinguished road
The rear speed sensors are easy to see from underneath the rear of the truck. They are right on the inside behind the parking brake linkage. They are round plastic bits with a tab going to the middle of the truck and one bolt going into it. You can also follow those lines up to the top of the shock tower to make sure they are not nicked or anything. You can see it without lifting but lifting could help.
biggestmexi is offline   Reply With QuoteReply With Quote
abs , correct , lift , search , truck
Balancing Issue with new Michelin Tires popalzai 4th Gen T4Rs 21 05-08-2018 08:47 AM
Tires Rubbing issue sgaustin83 4th Gen T4Rs 23 11-15-2016 12:42 PM
Issue fitting tires? dshill23 4th Gen T4Rs 2 06-29-2015 01:46 PM
steering issue with bigger tires LimitedRunner11 5th gen T4Rs 14 02-09-2015 04:45 PM
Steering Issue...New tires or Caster? Instructor 5th gen T4Rs 9 06-11-2013 07:45 PM
