Old 09-05-2020, 03:12 PM #1
Doc3g Doc3g is offline
Doc3g will become famous soon enough
ABS issue after lift and tires
Sorry if this has already been asked, but the search function won't let me search for "ABS" by itself and I couldn't find anything in the FAQ's about this, so here goes:
I had a Toytech Alumaseries 3" lift installed and 285/75 R17 KM3's on Fuel 17x8.5 rims (D557's). The truck drives and rides good but now every time I come to a stop the truck does a little abs "burp" like I'm sliding on ice. I've rarely had occasion for the ABS to engage prior to this.
So, my question is, is this common and if so, how do I correct it?
Doc3g is offline   Reply With QuoteReply With Quote
Old 09-05-2020, 03:19 PM #2
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
On the 4th gen you really need to do a ZPC if you mess with the suspension.
You are basically changing the angle of the body after lift.
Computer needs to learn new current state of the t4r.
Maybe similar with the 3rd gens?
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 09-05-2020, 07:44 PM #3
biggestmexi biggestmexi is offline
biggestmexi is on a distinguished road
recently did a lift and did not have to mess with the wheel speed sensors or anything.
Check your wire to the speed sensors or check the ABS Codes
  • Find the "DIAGNOSTICS" connector that's on the drivers side of the engine, on the high edge of the intake plenum.
  • In the lower left of the inside of the "DIAGNOSTICS" connector, you'll find a small plug that pulls out. That's a "shorting pin", remove it from the spot.
  • Now use a piece of wire to jumper from E1 to Tc. (connecting the contacts)
  • Go into the truck and turn the key forward to ACC mode.
  • Watch and count the blinks of the (ABS) light.
  • With the light blinking, it will blink a number of times and then short pause then blink again. This will give you the 2 digit code. Wait for the code twice as you might have more than one code. a Long pause between numbers means it is another code.
Below are the codes:
Then you can start from there.
Hopefully the edit will clear it up better.
biggestmexi is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 12:22 AM #4
Thanks, I read some other posts about this as well, but there doesn't seem to be a write up that I can find on how to do it. Am I just missing it or does it not exist?
Old 09-06-2020, 12:33 AM #5
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Do you have specific question about the procedure posted above? There isn't really anything more to it than what was spelled out above. I did a quick search and found this not great video which should show you how simple it is.
Skulking is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 02:25 PM #6
Thanks for the video. I guess I thought the troubleshooting was indicated if the abs light was on (and mine is not), whereas the ZPC was like resetting the sensors so that they could relearn when to apply the abs (and I am assuming that the ZPC is a separate procedure compared to the troubleshooting jumpering in the video)?
Old 09-06-2020, 02:35 PM #7
TravThePro's Avatar
TravThePro TravThePro is offline
Real Name: Travis
TravThePro is on a distinguished road
TravThePro's Avatar
Real Name: Travis
I unplugged my abs after it nearly killed me twice up in the mountains. I would suggest considering this if you have an early model 3rd gen. Good luck, I hope your solution isn't too expensive.
1996 T4R
TravThePro is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 02:59 PM #8
I didn't realize you were asking about ZPC rather than the ABS light. I've never needed to deal with a ZPC for my 4runner. I don't know what year yours is, but I did find this thread with instructions which seems to cover the 01/02.
Old 09-06-2020, 05:18 PM #9
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
The 4th gens seem to be hyper sensitive to body angle change, front rake.
Thats why i mentioned it.
I have never had my hands on a 3rd gen, sorry i dont know the procedure.
I just do a ZPC when ever i mess with the suspension anymore.
Cheap and easy to diy.
I get sick of that trac control nanny yelling at me.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 09-06-2020, 10:11 PM #10
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
OP, what year is your 4Runner? 96-00 have a very simple ABS system. It's a set of "gears" with magnetic pickup sensors, one for each wheel, sensor wires, and an ECU. If you are having trouble with the system and you just put a 3" lift on, I'm going to guess those ABS wires are stretched too far or one has torn. You'll need to find a way to loosen the sensor and wiring and replace any that are damaged.
Be prepared to replace your suspension and steering components a lot more often. Inner tie rods don't like big lifts and will wear out prematurely.
326WHP 347TQ
Old 09-07-2020, 12:59 AM #11
It's a 99. Will the ABS stay the same if I do the tundra brake rod? I've always hated the stoke brakes.
Old 09-07-2020, 04:35 AM #12
Real Name: Jerod
Real Name: Jerod
In my experience, it gets better. I had several times where my ABS would lock up in rainy weather prior to doing the Tundra brake swap. Afterwards it never kicks on in the rain. The TBU is not a guarantee to improve the ABS system though, it only helps since you'll need less pedal pressure to achieve the same stopping power if done right with quality rotors and pads. Having a good pair of all weather tires goes a long way too. Dedicated snow or mud tires with aggressive treads will also set off the ABS sensors more since there's less rubber contacting the road, increasing the chance of wheel slip.
326WHP 347TQ
Old 09-07-2020, 06:19 PM #13
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
Dealing with this right now after an upper ball joint and cv axle replacement. I had to pull the speed sensors so I could remove the knuckle to press the new ball joints in. The driver side speed sensor was pretty rusted into the knuckle. I had to do a lot of twisting and pulling to get it out, and the inside of the bore or whatever was pretty rusted also. Based on my research, I'm hoping a little better cleaning of the rusted surface the sensor sits on will fix it.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 09-08-2020, 01:58 AM #14
OK, I have BFG KM3's on there, so they are pretty aggressive.
That's good to know, keep me updated if it fixes the problem, maybe I'll just look into replacing mine, they are 21 years old with 300K miles on them.
Old 09-08-2020, 08:11 PM #15
Real Name: Joe
Real Name: Joe
Ok I think I fixed mine and it was stupid easy... apparently the torque on the speed sensor bolt is pretty important. I didn't torque these when I reinstalled them, and decided to go out and torque them to spec of 71-in pounds. The driver side was close but the passenger was fairly loose. After torquing no more abs engagement when coming to a stop at slow speed.
abs , correct , lift , search , truck
Balancing Issue with new Michelin Tires popalzai 4th Gen T4Rs 21 05-08-2018 08:47 AM
Tires Rubbing issue sgaustin83 4th Gen T4Rs 23 11-15-2016 12:42 PM
Issue fitting tires? dshill23 4th Gen T4Rs 2 06-29-2015 01:46 PM
steering issue with bigger tires LimitedRunner11 5th gen T4Rs 14 02-09-2015 04:45 PM
Steering Issue...New tires or Caster? Instructor 5th gen T4Rs 9 06-11-2013 07:45 PM
