Old 09-09-2020, 05:48 PM #1
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
F150 Fuel Tank + Toyota Sending Unit Kit
Many of us are switching out our stock fuel tank for an F150 tank located in the factory spare tire area (you can read about all of that here). There are some major advantages in doing this swap: increased ground clearance, better weight distribution, and freeing up space in-front of the axle to change the rear suspension link geometry. Though one of the major disadvantages has been the in-ability to integrate the sending unit to allow the factory fuel gauge to work. Some people have done it ( @midcoma and @2TH4IST are the only ones I know of), but it has required extensive work which includes major cutting of the tank and sheet metal welding.
In an effort to find a better solution, I have developed this kit. This kits integrates the OEM Toyota sending unit onto the F150 fuel pump assembly in order to retain the factory fuel gauge. I have done my best to make this kit as easy of a swap as possible using only basic tools.
Kit Price: $100 shipped
Kit Contents:
1 x Toyota Sending Unit Conversion Bracket
4 x In-tank Butt Connectors (only 3 are needed, 1 extra has been provided)
8 x Heat Shrink Butt Connectors (only 7 are needed, 1 extra has been provided)
1 x Packet of Silicone Grease
1 x Bulkhead Connector
1 x One-Way Retainer Clip
1 x In-tank Grounding Wire
1 x In-tank Wiring Harness (with pre-stripped ends)
1 x Outside-tank Wiring Harness (with pre-stripped ends)
Parts you should already have:
1 x 1990-1997 F150 Rear Fuel Tank Assembly (Spectra F1G1FA or equivalent)
1 x Toyota Sending Unit P/N 83320-35590 or P/N 83320-35620
>> Installation Instructions <<
>> Wiring Diagram <<
Notes:
  • This kit is made for 1999-2002 4Runners, this kit will NOT work on 1996-1998 4Runners. Starting in 1999, Toyota switched to a digital odometer and the way the fuel sending unit works is by a digital reference from the dash, and the sending unit geometry and electronics completely changed. The bracket and wiring harnesses in this kit have been designed to only work with these 1999-2002 Toyota sending units. If you have a 1996-1998 4Runner and want your factory fuel gauge to work after swapping fuel tanks, I believe you can get your gauge to work (minus the low fuel light) by using a fuel calibration device (see Classic Instruments Fuel Link, MeterMatch Fuel Gauge Interface Module, or similar device).
  • The bracket only works with the Toyota Sending Unit P/N 83320-35590 (1999-2001 model years) or P/N 83320-35620 (2002 model year). Sometime in late 2000, Toyota had a service bulletin TSB EL010–00, which replaced the (sometimes defective) sending unit P/N 83320-35530 with P/N 83320-35590. The geometry changed between these two versions, the bracket in this kit is designed to fit the later version. So if you have a model year 2002, your OEM unit should work. If you have a 1999-2001 model year and had your vehicle serviced from TSB EL010–00, then your sending unit will work. Some 2001 model years will have the old unit and some will have the new unit, it depends on the production date. If you have a 1999-2000 model year and have not had your vehicle serviced from TSB EL010–00, you need to purchase the new sending unit (P/N 83320-35590).
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 05:49 PM #2
Team_Jake's Avatar
Team_Jake's Avatar
I do not have my F150 fuel tank installed, I am not at that point yet, but I want to get this kit out as soon as possible for those that need it. I have verified that everything functions the way it should, but in a scientific manner. I want to verify that everything functions exactly the way it should in the real world, so I am looking for someone that can install this in their vehicle and in a relatively quick timeframe (by or before next weekend, September 19th/20th), and report back to me their findings. I will send them a full kit at no cost and my preliminary installation instructions. I will give first priority to the following individuals since they have reached out to me expressing interest in a kit.
@eimkeith
@rickashay
@Rockdawg84
@xweslingx
@3rdgensr5
@Jsimp11
Edit: @Jsimp11 will be getting the first kit and will verify the functions and installation instructions.
In the meantime, I will now be taking pre-orders with the hope that orders will be ready to ship out once I get validation that everything works. Please respond to this thread if you are interested and I will DM you, or send a DM to me.
Thank you!
For confirmed pre-orders, so far I have:
@eimkeith
@rexassian
@sleepydad
@infamousRNR (2 kits)
@rickashay
@wrench.n.wheel
@3rdgensr5
Old 09-09-2020, 06:47 PM #3
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
I have a '96 but I'm buying a kit regardless.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 06:53 PM #4
Team_Jake's Avatar
Team_Jake's Avatar
Would you like just the wiring (everything minus the bracket)?...because the bracket won't work.
Old 09-09-2020, 07:11 PM #5
rexassian rexassian is offline
rexassian is on a distinguished road
I'm in for a kit, this will be my next big project; after my current projects on my 4runner...
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
rexassian is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 07:18 PM #6
Jsimp11 Jsimp11 is offline
Jsimp11 is on a distinguished road
I’m in the process of installing mine now. Just ordered the hoses and fittings to hook it up. So i can put it in and test it out
Jsimp11 is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 07:29 PM #7
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
no, I want everything. I like to fiddle with different parts
keith
eimkeith.com
Old 09-09-2020, 08:35 PM #8
Team_Jake's Avatar
Team_Jake's Avatar
Thanks! Sending the first kit your way.
Old 09-09-2020, 09:31 PM #9
2TH4IST's Avatar
2TH4IST 2TH4IST is online now
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
Ah man, I truly wish I had this when I did my tank swap. @Team_Jake that is awesome work. It was a royal pita getting the stock stuff to work in the tank, I think this will speed up that process substantially for other people that are interested in doing this swap.
Trust me it's worth it! Even if I never change my link locations from stock it frees up a boat ton of room for things like a air tank and compressor ect. But I digress. Just for refrence this is what I had to do to get the stock pump to fit in the tank, and then the sender.
Edit to add more pics.
F150 Fuel Tank + Toyota Sending Unit Kit-20200128_194904_compress93-jpg  F150 Fuel Tank + Toyota Sending Unit Kit-20200523_130846_compress5-jpg  F150 Fuel Tank + Toyota Sending Unit Kit-20200128_194934_compress94-jpg  F150 Fuel Tank + Toyota Sending Unit Kit-20200128_194952_compress67-jpg
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is online now   Reply With QuoteReply With Quote
Old 09-09-2020, 10:28 PM #10
Team_Jake's Avatar
Team_Jake's Avatar
Yeah, basically when I realized how much work it would take to cut, weld, fab everything into the F150 tank, I knew there had to be a better way. I hope to get my tank swapped soon.
Old 09-10-2020, 10:01 AM #11
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
@Team_Jake
Following.. How long do you see yourself providing this kit? The fuel tank swap is on the list, but it's not high priority right now. I just don't want to miss out.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 09-10-2020, 11:33 AM #12
Team_Jake's Avatar
Team_Jake's Avatar
Originally Posted by JWaldz View Post
@Team_Jake
I have enough parts to make 25 kits total. I don't expect this to be a huge seller, my guess is it'll take a year or two to sell all 25. If later down the road inventory is starting to get low I'll let you know.
Old 09-10-2020, 05:56 PM #13
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
How much for the cat?
keith
eimkeith.com
Old 09-10-2020, 10:23 PM #14
2TH4IST's Avatar
2TH4IST's Avatar
@eimkeith I asked Chuck, said cat. He said meow. Gave me the side eye and walked away. (Cats not for sale lol).
F150 Fuel Tank + Toyota Sending Unit Kit-20200224_175406_compress78-jpg
Old 09-10-2020, 11:02 PM #15
Team_Jake's Avatar
Team_Jake's Avatar
Installation instructions and a wiring diagram have been posted in the first post. More pictures/illustrations will be added in the future.
kit , p/n , sending , toyota , unit
F150 fuel tank? gainman 5th gen T4Rs 3 08-16-2020 07:11 PM
F150 Auxiliary Tank Fuel Filler Rcastle 3rd gen T4Rs 5 01-21-2020 05:53 PM
WTB fuel sending unit ed4stoy88 Want to Buy/Trade 0 01-22-2014 02:50 PM
Looking for gas tank with fuel pump and sending unit Reggie Want to Buy/Trade 0 10-20-2013 08:08 AM
Need a favor for gas tank sending unit. Bad_Vision Classic T4Rs 6 02-10-2011 10:21 AM
