Old 12-08-2020, 12:58 PM #31
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
Originally Posted by MN4runnerman View Post
So is there any space left to get in on this?
Thanks!
Yes, absolutely! I'll send you a DM.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 04:18 AM #32
LowellWatt's Avatar
LowellWatt LowellWatt is offline
LowellWatt is on a distinguished road
LowellWatt's Avatar
I'm in for a kit, sending a DM!
LowellWatt is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 09:25 PM #33
LowellWatt's Avatar
LowellWatt's Avatar
Alright, got the kit ordered (thanks @Team_Jake !), and trying to plan for the fun ahead:
First, I'm trying to accomplish the tank swap and retain the emissions controls for A) no CELs and B) passing local emissions tests (not Cali), so I'm trying to integrate/accommodate whatever's necessary to keep the computer from freaking out.
I have an '02, which has the obnoxious charcoal canister above where the spare normally sits. There's about a billion vacuum lines in and out of that thing, two of which connect to the fuel tank (tank vent valve and cutoff valve), and two of which connect to the filler neck.
The tank vent valve itself has a column that extends down into the stock tank. Everything on the stock tank is mounted (I think) well above the full level, i.e. it's not constantly submerged in fuel. Is there any danger swapping the Toyota tank vent valve assembly onto the F150 tank, where it will likely have most of that column under the fuel level?
The F150 tank has a small hole in the middle for the EMS valve; the Toyota cutoff valve is the equivalent to this, correct? Is there any reason not to just use the Ford EMS valve and connect it to the charcoal canister?
Old 02-16-2021, 03:21 PM #34
wrench.n.wheel's Avatar
wrench.n.wheel wrench.n.wheel is offline
wrench.n.wheel will become famous soon enough wrench.n.wheel will become famous soon enough
Checking back to see if anyone has installed with this kit, I'm picking up my F150 tank from HotMetalFab from @AssBurns rig.
Also, @Team_Jake , would you think this fuel pump would work fine with this kit? Quantum 340LPH Direct Drop-In Rear-Tank Fuel Pump Assembly for Ford 1990-1996, Replaces Airtex E2064MN
I'm supercharged and 100' elevation so I need all the fuel I can get.
'99 Millenium Silver SR5 | 5.29 Nitrogears/ARB lockers | 35s | Supercharged
Build Thread
wrench.n.wheel is offline   Reply With QuoteReply With Quote
Old 02-16-2021, 03:33 PM #35
Team_Jake's Avatar
Team_Jake's Avatar
As long as the pump has the same mounting locations for the sender and no obscure geometry gets in the way of the sender or the arm, then it should work without issue. From what I can tell from the photos, it should work.
Old 02-16-2021, 05:03 PM #36
Thank you. I might do this if the stock ford pump gives me issues.
Build Thread
Old 02-16-2021, 05:30 PM #37
Team_Jake's Avatar
Team_Jake's Avatar
Keep us updated if you do try this pump. I think we'd all like to have the option to switch pumps if the stock one proves to not be able to handle full throttle or a supercharger.
Old 06-03-2021, 11:22 PM #38
KingJew1902 KingJew1902 is offline
KingJew1902 is on a distinguished road
hi TeamJake, Id like to order this kit. Please send me contact information cferguson131218@yahoo.com
KingJew1902 is offline   Reply With QuoteReply With Quote
Old 06-04-2021, 02:04 AM #39
Team_Jake's Avatar
Team_Jake's Avatar
PM'd
Old 12-23-2022, 05:22 AM #40
Tswayzee Tswayzee is offline
Tswayzee is on a distinguished road
Any of those kits left?
Tswayzee is offline   Reply With QuoteReply With Quote
Old 10-20-2023, 07:55 AM #41
Eternal1 Eternal1 is offline
Eternal1 is on a distinguished road
Are you still making these kits?
Hello Jake, I would be very interested in one of your kits. I hope you are still putting them together. It would be a major time saver. Please let me know.
ericdclifton@gmail.com
On a side note, I used to live in Elfin Forest/San Marcos. I now live in Wyoming but it is fun to see you are in Vista. Cheers! Eric
Eternal1 is offline   Reply With QuoteReply With Quote
kit , p/n , sending , toyota , unit
F150 fuel tank? gainman 5th gen T4Rs 3 08-16-2020 07:11 PM
F150 Auxiliary Tank Fuel Filler Rcastle 3rd gen T4Rs 5 01-21-2020 05:53 PM
WTB fuel sending unit ed4stoy88 Want to Buy/Trade 0 01-22-2014 02:50 PM
Looking for gas tank with fuel pump and sending unit Reggie Want to Buy/Trade 0 10-20-2013 08:08 AM
Need a favor for gas tank sending unit. Bad_Vision Classic T4Rs 6 02-10-2011 10:21 AM
