Old 09-10-2020, 07:46 AM #1
19963.4lsr5 is just really nice 19963.4lsr5 is just really nice 19963.4lsr5 is just really nice 19963.4lsr5 is just really nice 19963.4lsr5 is just really nice
I’m pretty sure it’s dead Jim. Rear drivers lower link mount broke off frame.
This really sucks. Just got it how I want it. I知 sure this is fatal and non repairable
Old 09-10-2020, 08:16 AM #2
thegipper's Avatar
thegipper thegipper is offline
thegipper has a spectacular aura about thegipper has a spectacular aura about thegipper has a spectacular aura about
thegipper's Avatar
Looks fixable to me. Why wouldn't you be able to fix it?
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 09-10-2020, 09:10 AM #3
spartacus's Avatar
spartacus is a glorious beacon of light spartacus is a glorious beacon of light spartacus is a glorious beacon of light spartacus is a glorious beacon of light spartacus is a glorious beacon of light
spartacus's Avatar
Frame swap'time.
Old 09-10-2020, 09:16 AM #4
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
It's gonna take some fabrication but it's repairable. You'll likely end up having to cut more of the frame out so whoever repairs it has good steel to weld to. If you weld to rusting metal, it'll just fail again. This will also likely result in having to replace the body mount bracket as well, which by the looks of it wouldn't hurt to be replaced. What's the rest of the frame/area look like?
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | RMRacks | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 09-10-2020, 10:16 AM #5
That痴 my worry. It痴 got 281,000 miles on it and this failure was pure stealth. Rusting from the inside out. I知 Leary on how good the rest of it is.
Where it broke away from the frame should be clean metal not rust like it痴 been cracked for awhile.
I need to figure out who to talk to to see if it can be fixed.
Old 09-10-2020, 09:55 PM #6
Devbot's Avatar
Devbot Devbot is online now
Real Name: Devan
Devbot has a spectacular aura about Devbot has a spectacular aura about
Devbot's Avatar
Real Name: Devan
Any welder worth their salt can fix a basic frame crack - small cracks/splits are NOT the end of the world. Watch any video of someone fixing a barn find and they typically gotta touch up multiple parts of the frame. As said it's gonna need a little metal fab to ensure you have something to zap onto, but it's not like it's twisted or corroded beyond belief. If you're curious if any other spots are weak, smack around hard with a hammer - if you make a hole, it's shot. Redneck way of testing integrity but it's fool proof, somewhat.
PA is in the salt belt, yeah? Might be worth it to do a good inspection
Y2K Highlander Millennium Silver 3.4L auto @ 290k and climbing
TRD coils / Tundra 5100s / Total Chaos Diff Drop / Dobinson 210v / Tokico Blacks / Vision Soft 8's / Widepeak AT3W 285s / EimKeith PCK / Spiker Hood Struts / Hood Scoop LED Mod / SRQ Corner Lights + Filler Panels + Grille w/ Raptor Lights / LED Interior / Daystar Stops / SS Brake Lines / Elbow Delete + ISR + O Gasket / Big 3 / Rear Diff Breather / Drivelines NW prop rod
Devbot is online now   Reply With QuoteReply With Quote
Old 09-10-2020, 10:20 PM #7
clearock clearock is offline
clearock will become famous soon enough
In my exp when to see/find this type of rust damage it's not isolated and even if u fix ur current issue more will arise, U can not weld rust... anything can b fixed $ but is it worth the cost.
clearock is offline   Reply With QuoteReply With Quote
Old 09-10-2020, 11:47 PM #8
jross20's Avatar
jross20 jross20 is offline
jross20 will become famous soon enough jross20 will become famous soon enough
jross20's Avatar
Welding time, then I'd work on painting the frame
Old 09-11-2020, 11:03 AM #9
I知 pretty sure it痴 dead Jim. Rear drivers lower link mount broke off frame.
A member suggested this for the repair. And I can weld mig and TIG and stick. I have a millermatic 130.
Old 09-11-2020, 11:10 AM #10
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Not the end of the world. Fix it if you like the 4runner
2000 SR5 4x4, Auto | Millennium Silver and Moon Mist | Eibach / OME / BTF Fab| Steelies | TBU| KM2 | Shrockworks skids | Onboard Air | Manual Hubs | Alpine Audio
WeakSauz is offline   Reply With QuoteReply With Quote
Old 09-11-2020, 11:18 AM #11
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
That kit will work. I just build my own. You can fix this and that's didnt come off bad.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 09-11-2020, 12:14 PM #12
I値l need to drop the tank and axle and maybe the running board. I expect problems with the running board and gas tank.
Old 09-11-2020, 12:41 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I never pulled the axle for welding. Would probably make it easier to repair. Running board and tank bolts will pita. Most running board bolts wont come out and snap along with a few tank bolts too. Watch bringing the tank down. As the plugs need unplugged from under the back seat plate. Careful not to catch any emmision houses. Being yours is not a 2001 or 2002 you have alot less hoses to deal with.
I mostly pull the tank return line as use my fuel pump to empty the tank. While you have that down. Check it all over with the filler tubes for issues.
That inner rail next to the tank will most likely be rusted out.
Old 09-11-2020, 07:45 PM #14
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
If you're anal like most I'd recommend a 220 welder, I used a Lincoln 120 at my house for my panhard correction brackets and it was unnecessarily shitty. Still got proper penetration, barely, but MAN does it look sloppy
Just my 2 cents
Old 09-11-2020, 07:53 PM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Just my 2 cents
Extremely good advice. Its alot harder to weld 1/8 plate with 120volt welder. Yes you can do it. However, its alot easier and better welds with a 220 volt welder as your amperage will be a lot higher and easier to do.
fatal , iphone , i知 , repairable , sucks
Lower Shock & Link Mount Reinforcement eimkeith 4th Gen T4Rs 21 05-10-2020 02:39 PM
Upper & Lower Link Mount Reinforcement! (ULR & LLS) eimkeith 3rd gen T4Rs 49 07-17-2019 11:21 AM
Lower Link Mount Reinforcement rkntoy 3rd gen T4Rs 9 12-06-2018 07:40 PM
Woman in stolen SUV eludes police after running over Dallas officer’s foot CoolMax General Discussions 4 02-10-2016 01:27 PM
Frame failure at rear lower control link mount Steve240 3rd gen T4Rs 1 05-20-2015 05:11 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
