Old 09-18-2020, 03:12 PM #16
MagusWyatt's Avatar
MagusWyatt MagusWyatt is offline
MagusWyatt will become famous soon enough
MagusWyatt's Avatar
Originally Posted by PRG3K View Post
I thought my '98 Limited would fall into this category as it has an alarm, but its not the RS3000 factory one with the module under the seat. Its something else. I think the module is behind the kick panel on the left side of the drivers footwell. There's a tiny 'on off' toggle switch down there and there's a red security LED light on the row of switches just left of the steering wheel. Any ideas? I want one of those nice, streamlined key fobs too. I hate my current one. I wonder if the programming would be the same or if that fob wouldn't even work at all.
edit - reason I ask is some people have mentioned having similar setups to mine on the YT video's for programming these fobs
thanks
Any system on a model before '99 is going to be an add-on system, so the body ECU (the module with the green button to program the remote) is what you need to find. From what I've seen it's usually under the driver's seat, but could theoretically be anywhere. It could be what you're seeing behind the driver's side kick panel. I don't know what the toggle switch is, but look for a green button. That's what you're going to use for the programming steps.
The grey RS3000 fob that I linked in my previous post should work for you.
1998 SR5
MagusWyatt is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 03:15 PM #17
MagusWyatt's Avatar
MagusWyatt's Avatar
Originally Posted by texadelphia View Post
Update...the $60 fobs from Amazon arrived yesterday. Packaging and everything was exactly the same as the $40 fobs I got from eBay and they also don't work. I guess my next step is to try a grey set and see if those work.
Wow, 60 bucks? At least you can confirm that they don't work, I suppose, and you can get refunds anyway. That grey RS3000 is only 35 and should be the answer to your problems.
1998 SR5
Old 09-18-2020, 04:31 PM #18
PRG3K PRG3K is offline
PRG3K is on a distinguished road
Thanks. I'll give it a shot.
'98 Desert Dune Limited (200K+)
PRG3K is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 05:43 PM #19
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
I tried getting one for my '98...did all my research, and it still didn't work
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 09-19-2020, 01:48 PM #20
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Those prices are for 2 fobs just FYI.
I have the set I bought on eBay and the set I bought on amazon packed up for return and the return addresses are the same despite being different seller names so there is zero difference between the amazon and the eBay options...Amazon is just more expensive.
Sent from my moto x4 using Tapatalk
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 11:17 AM #21
MagusWyatt's Avatar
MagusWyatt's Avatar
Ahhh, okay. That makes much more sense.
It's funny, sometimes Ebay seems like the cheaper, less reliable option, but it clearly has a lot of the same sellers. I guess you just have to watch out for fly-by-night companies, but the rating system actually makes that a bit easier.
1998 SR5
Old 09-25-2020, 06:45 PM #22
Grey key fobs showed up today and they don't work either. Is it possible that I have a weird one-off alarm system? Is there one that could be installed at the dealer if it didn't come with it from the factory that uses a different key fob?
Old 09-28-2020, 05:11 PM #23
MagusWyatt's Avatar
MagusWyatt's Avatar
Wow, really? You got these exact ones and they aren't working?
If you found that body ECU with the green button and followed the instructions, then I'm all out of ideas.
1998 SR5
Old 10-04-2020, 12:41 AM #24
These are all the ones I've tried. They've all come from New Jersey and come in the same exact packaging so I suspect they're all coming from the same parent company.
Amazon.com: For 90-97 Toyota Keyless Entry Remote Key Fob Dealer Installed Systems RS3000 BAB237131-022, 08191-00922 - BLACK: Automotive
Amazon.com: KeylessOption Keyless Entry Remote Control Car Key Fob Replacement for Toyota RS3000 BAB237131-022 (Pack of 2): Automotive
2 Replacement for Toyota BAB237131-022 RS3000 Key Fob Remote Grey | eBay
2 Replacement for Toyota BAB237131-022 RS3000 Key Fob Remote Black | eBay
Old 10-04-2020, 03:52 AM #25
MagusWyatt's Avatar
MagusWyatt's Avatar
Yep, those are all confirmed not to work. I'm telling you, buy the one I linked. I know, it looks exactly the same, but it's not! Look at the part number.
EDIT: Wait a minute, the links have changed since I posted them! Grrrrr. The first link I posted is broken now, and the second goes to one that is no longer the same product. This happened within the last week. I checked my order history and it's the first link, which is now broken. Says the product doesn't exist. Sorry man, wish I would have gotten the 2-pack so I could just send you one!
EDIT EDIT: Okay, even though the second link I put up is a different listing, it looks like it's just a two-pack of the same part number that I got. I know it says 1998-2001, but if you have the same body ECU with the green button, then it should work for you. Here's the link again: Amazon.com: For 98-01 Toyota Keyless Entry Remote Key Fob Dealer Installed Systems RS3000 BAB237131-022, 08191-00922 - GREY - 2 PACK: Automotive Can't hurt, you've already tried everything else!
1998 SR5
Old 10-04-2020, 01:21 PM #26
Thanks! I didn't even think to look at part numbers. Just been looking at the transmitter ID code. Just placed the order. Here's hoping!
Old 10-04-2020, 10:20 PM #27
wrpsuite wrpsuite is offline
wrpsuite is on a distinguished road
a little off topic but bot my fob's were trashed so i had a viper remote start installed and came with new fob's. its nice on those cold days too. only thing is no more button for rear window auto roll down but can live without it or use my old fob as necessary..
wrpsuite is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 01:18 AM #28
MagusWyatt's Avatar
MagusWyatt's Avatar
Fingers crossed. Let me know if it works!
1998 SR5
Old 10-10-2020, 10:36 PM #29
No dice. I can't get any of these damn things to work.
Old 10-11-2020, 07:23 PM #30
Went the eBay route and got an old OEM one. If that doesn't work, I'm at a loss.
aftermarket , entry , fobs , keyless , original
Is my keyless entry remote original or aftermarket? ArmArak 3rd gen T4Rs 16 06-29-2020 11:36 PM
Aftermarket keyless entry paired with a OEM fob aa.allen 3rd gen T4Rs 2 08-12-2017 07:53 PM
OEM Illuminated Entry and/or Dome Supervision with Factory Keyless Entry? hungwin jza80 3rd gen T4Rs 5 12-10-2014 05:43 PM
**SOLD** 2 NEW keyless entry fobs - 2 button gray - BAB237131-022 Qyota Classifieds - buy & sell (no commercial ads please) 9 07-12-2010 01:33 PM
Do you need new key fobs? 3rd gen RS keyless system fobs here Qyota 3rd gen T4Rs 5 06-24-2010 11:41 PM
