Old 09-13-2020, 12:03 PM #1
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
Still working toward a flat belly... (clocking the factory transfer case)
quick update on my flat belly progress: you guys have already seen the tank relocation and rear bumper work, and I'm closing in on a high-clearance transmission crossmember design as well.
However, this morning I was finally able to test fit the prototype clocking ring for the J-shift transfer case:
pretty stoked about this, to be honest.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 05:21 PM #2
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Solid work as always.
The funny thing is I've just been wheeling the shit out of my non-flat bellied rig. The only place I ever get hung up is the rear diff. Everything else just slides right along my skids. Do you really think this will give that big of an advantage in big rocks?
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 05:43 PM #3
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
I agree the best solution I've seen is guys building custom armor over the transmission n transfer case and they just slide or bounce over big rocks n never worry bout damage to their armor because it is cheap to repair or replace
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 06:03 PM #4
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
I think of it in terms of equivalent lift height - this is worth 2-3 inches of clearance without the additional 2-3 inches of lift, so the CoG stays low. Sliding on the skids is fine, but clearing more stuff might be good too.
also, while our 3rd gen 4Runners are blessed with a good wheelbase; my 1st gen Taco extended cab is not. This is good for the goose and gooder for the gander. (?)
keith
eimkeith.com
Old 09-13-2020, 08:38 PM #5
papabeach's Avatar
papabeach papabeach is offline
papabeach has a spectacular aura about papabeach has a spectacular aura about papabeach has a spectacular aura about
papabeach's Avatar
I was excited to see this thread, you do solid work. Now to see this with dual cases!!!
(SOLD)1999 4Runner SR5, 5spd-R452d 5th, 4x4 “Highlander”
Supercharged, Lifted, Dual cased, Dual Locked, Geared, Armored and more...
Papabeach Mod Thread
(SOLD)1997 Land Cruiser FZJ80
1979 FJ40L-KC
papabeach is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 12:44 AM #6
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
It's not that the belly gets hung up, it's that it gets hit. It also has the potential to cause high centering if it does get hung up.
As someone who has ran a flat belly, it's definitely worth it if you can accomplish it. Just like a portal axle would keep your diff off the rocks at the same ride height. Sure you can bounce and bang your way through a trail, but why do that if you can make it without the belly touching anything?
It's especially nice if it's a daily driven vehicle. There's a lot less bumps and bangs that make you worry if you broke something or not.
midcoma is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 10:42 AM #7
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
I was able to test fit the transfer case this morning:
this is with a 1.25" body lift, of course.
keith
eimkeith.com
Old 09-20-2020, 10:51 AM #8
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
Installation involves drilling out the 4 m8 threaded holes on the transmission to 5/16" studs and spotfacing the cast surface for the nuts, and cutting down the passenger shift rail on the transfer case to just beyond the seal mark so that it will clear a boss in the transmission housing when assembled.
I used a cutoff wheel to chop the shift rail as well as spot facing the transmission housing.
I'm working on the shift lever relocation today as well.
keith
eimkeith.com
Old 09-20-2020, 07:15 PM #9
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
shifter relocation is going to work out fine as well - this will involve cutting the transfer case shifter at the bend, then welding the new plate between the two halves to relocate the shift lever to it's original position:
(kind of a long day today, but successes all around, so I'll take it!)
keith
eimkeith.com
Old 09-21-2020, 01:24 PM #10
That's pretty close... What are the trans mount+body mount plans to keep those from contacting? (or just a bit love to the floor?)
I'm very curious how the shifter is going to feel with that offset bracket in place.
Cool stuff!
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-21-2020, 02:06 PM #11
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
Cool stuff!
I have the 4xInnovations trans mount and Energy Suspension body mounts installed already (in preparation for this modification.)
I have no doubt there may be contact from time to time wheeling, but I doubt it will be much.
Similarly I doubt there with be any perceptible change in shifter feel - it’s only around 4” offset.
keith
eimkeith.com
Old 09-21-2020, 10:08 PM #12
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
U working out something that will use the OEM trans cross braces or getting even more clearance by removing said and making a new system.
clearock is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 08:13 PM #13
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
both factory crossmembers are going away.
keith
eimkeith.com
Old 09-22-2020, 10:00 PM #14
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Will this crossmember work with single and dual cases?
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 07:25 AM #15
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
yes, ultimately I want to use it in both my T4R with the single clocked case and in my 1st gen Tacoma with the duals/Lefty setup, so I'm setting it up to work both ways.
keith
eimkeith.com
belly , crossmember , flat , high-clearance , transmission
Did OEMValue.com went belly up? Christian Engines / Suspension / Wheels / Tires / Audio / Accessories 9 01-20-2020 02:25 PM
Stock belly pan ? sport05 3rd gen T4Rs 3 08-23-2015 08:30 PM
Any cats stolen with belly pan WHORERUNNER 3rd gen T4Rs 4 03-17-2014 04:53 PM
Belly pan? UPS92008 4th Gen T4Rs 14 12-29-2008 09:58 PM
