Old 09-13-2020, 09:48 PM #1
wrpsuite wrpsuite is offline
wrpsuite is on a distinguished road
Battery Light
Haven't been driving my truck much lately but last week when i started it battery light came on. Had tools with and headed to parts store thinking original alternator finally giving out and could die at any moment.
Tested voltage- 12.6 across terminals, charging at 14.7 skipped the purchase and drove home 3 hours, got home and load tested and it's fine started perfect all week just not sure why battery light is on?
wrpsuite is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 08:32 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Possible dirty terminals.
Old 09-14-2020, 08:31 PM #3
Will start there and see what happens thanks
Old 09-14-2020, 10:44 PM #4
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
I like how you think Brillo.
So many times we look past the more obvious and move on to the more complicated or expensive potential sources for the problem......i’m guilty of the same!
Best to start by eliminating the more basic and cheap ones first.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 09:50 AM #5
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
brillo's fix first.
another reason the battery light comes on is an LED swap. i just had to revert to incandescent on mine for that indicator.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 09:59 AM #6
Battery post cleaner and terminal remover should be in everyone’s toolbox.
Old 09-15-2020, 05:11 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
As old as these rigs are now. The chances of terminal and connections at the battery post being severely oxidized and those causing major resistance and bad conduction.
Old 09-19-2020, 10:13 PM #8
Cleaned battery, replaced terminals, checked ground wire, checked wires going to alternator and light still on. Making me crazy and worried to get stranded. May have to take alternator out and have bench tested.
Old 09-19-2020, 10:26 PM #9
Hit your Alt with a hammer. If the light goes out either replace the brush assemble or get another alternator.
Old 09-20-2020, 09:24 AM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Mostly the battery light comes on when the vehicle isn't charging. That's when mine came on.
So your getting 14.7 volts across the terminals when the engine is running is this at idle? As the these mostly dont charge much at idle.
Maybe your voltage regulator is failing and your voltage is going too high thus why your light is on.
Old 09-20-2020, 02:29 PM #11
12.7 when off
Drops to 11.5 when cranking
14.3 at idle
Smacked alternator battery light still on scratching head.
Old 09-20-2020, 02:39 PM #12
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Take it to a local auto parts store (NAPA if you have one) and have them load test it.
It seems to be charging, but possibly overcharging the battery.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 03:37 PM #13
Had it load tested when first came on not the problem but thanks
Old 09-20-2020, 04:03 PM #14
Battery Light
12.7 when off
14.3 at idle
What bulb do you have in for the battery light?
If you have an LED in it, it won’t work. The lamp is part of the circuit.
14.3 at the battery is good.
Old 09-20-2020, 04:41 PM #15
Stock light
battery , light , started , tested , week
Battery Light + Whine + Low Idle + New Battery TT4RLtdV8 4th Gen T4Rs 23 06-17-2022 09:51 PM
4th Gen No Codes No Start & Battery Light On, It's not the battery! V8Man 4th Gen T4Rs 18 10-05-2019 10:35 PM
Please help - Engine shut off + Battery light, A/T Fluid light and OIL light Lamer 3rd gen T4Rs 11 09-03-2018 06:04 PM
A/T Oil Temp Light and Battery light are on wilbertd Classic T4Rs 2 11-13-2017 11:55 AM
A/T Oil Temp Light accompanied by Battery light YotaDriver19 Classic T4Rs 5 09-28-2011 10:44 AM
