Old 09-20-2020, 06:35 PM #16
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Now I am starting to scratch my head as there has to.be a reason this light is on
brillo_76 is online now   Reply With QuoteReply With Quote
Old 09-21-2020, 11:34 AM #17
What is your voltage at the charge post of the alternator?
That light may also come on if the V regulator is failing and outputting too high of voltage.
If your voltage is above 14.5 at the post and you have jumper cables use them to ground the Alt to the negative post of the battery and frame.
Old 09-21-2020, 10:54 PM #18
wrpsuite wrpsuite is offline
wrpsuite is on a distinguished road
14.7 at the alternator post, can you elaborate on the test you mentioned?
wrpsuite is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 10:56 PM #19
mechanic friend told me he thinks reference wire in regulator is shorted and alternator is bad ??
Old 09-21-2020, 11:00 PM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I been saying bad terminals or alternator from the beginning.. I know when i was loosing my ground in the alt my ground lugs would glow red at night under the hood.
Old 09-22-2020, 12:28 PM #21
Take your jumper cables and clamp one end of the negative cable to your Alt housing and clamp the other end to your neg post of the battery. To see if the voltage goes down. I’ve never seen a Denso internally regulated push more than 14.2v
To me your VR is failing, a connection or two inside the Alt cover are loose or it’s not sensing voltage properly from a bad ground or something.
battery , light , started , tested , week
Battery Light + Whine + Low Idle + New Battery TT4RLtdV8 4th Gen T4Rs 23 06-17-2022 09:51 PM
4th Gen No Codes No Start & Battery Light On, It's not the battery! V8Man 4th Gen T4Rs 18 10-05-2019 10:35 PM
Please help - Engine shut off + Battery light, A/T Fluid light and OIL light Lamer 3rd gen T4Rs 11 09-03-2018 06:04 PM
A/T Oil Temp Light and Battery light are on wilbertd Classic T4Rs 2 11-13-2017 11:55 AM
A/T Oil Temp Light accompanied by Battery light YotaDriver19 Classic T4Rs 5 09-28-2011 10:44 AM
