4500 rpm is well under redline and there is no issue with it reving that high. The computer is just trying to maintain the speed you set the most efficient way. If for some reason you want to lug the engine and slow down while going up a hill, kick the CC off before.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
