Real Name: Rico
Real Name: Rico
I second the front driveshaft. Did PO mention doing any kind of maintenance where the driveshaft would have to be removed? They could of put it back wrong if you don't visibly see anything wrong with it. I'd lube the drive lines and either way since it's a new to you rig and see if that helps any.
18 MGM TRDOR: ARB classic rack, C4 ladder/ Front - Toytec 3" Non adjustable, JBA uca, Toytec diff drop/ Rear - Toytec Aluma 2.0 shocks, Superflex HD coils, KDSS drop brackets/ Toytec 1" BL, SCS SR8 et-10 17x8.5, Toyo RT 315/70r17, BMC/ Pedal Commander, TRD CAI, URD Y pipe, Borla Type-S
00 ltd elocker(sold): F tundra 5100's eibach 620 R lc 7.5 wraps tokico blacks, 1" toytec bl, pro comp 69's yoko MT's 285/75r16, jba offroad uca, toytec diff drop, 231mm tbu
