Old 09-17-2020, 11:30 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Not adjusted properly or the wheel cylinder has a plunger stuck.
You found your sqeek.
Old 09-18-2020, 12:01 AM #17
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Don't they self-adjust every time you pull the e-brake?
Sent from my moto x4 using Tapatalk
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 08:52 AM #18
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
They do, but only if your bell cranks aren't seized and the parking brake is adjusted correctly. New wheel cylinders for the rear are cheap. I got mine for $20 each. Make sure to replace your drums too.
Old 09-18-2020, 09:58 AM #19
The bell cranks seemed loose and mobile but I'll go through the e-brake adjustment just to make sure that's OK.
I was hoping not to get into replacing the wheel cylinders since they're not leaking but I guess it couldn't hurt.
Kind of going between refreshing everything and just getting the drums resurfaced and putting new shoes on.
Old 09-18-2020, 10:49 AM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
These E-Brakes are notorious for not self adjusting. Were the adjusters even or did someone have one out twice or 3x more then the other side. If the wheel cylinder plungers are moving freely. I would check that bell crank or the E-brake was stuck on burned the pad off. As the pivot point in the bell crank is always freezing on these rigs.
Old 09-18-2020, 11:53 AM #21
Only pulled the driver side last night. I'll compare the adjusters when I pull both drums this weekend. When I replace everything I'll probably pull the bell cranks out and make sure they're well lubed and not corroded.
Old 09-18-2020, 12:03 PM #22
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
That rear shoe is pretty worn down too. I don’t think that situation is too abnormal, they should have been replaced a long time ago.
I’d just do shoes and drums and clean things up properly. Make sure you lube all the correct points (see fsm). I’d try leaving the cylinders alone, maybe just check again in a few months to see it looks good still.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 12:09 PM #23
I was actually just throwing around this idea.
Is Sylglide good to use on these or is there something better?
Old 09-18-2020, 12:27 PM #24
Kanoe's Avatar
Kanoe's Avatar
I haven’t done enough of these to recommend anything. Hopefully someone else will. Sorry.
-2001 Echo D.D.
Old 09-18-2020, 06:17 PM #25
Pulled the passenger side drum to take them to get turned and found gear oil all over everything. My simple brake job just turned into an axle seal job.
This isn't how I envisioned the first week of ownership. Haha
Old 09-18-2020, 06:44 PM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Very common on these rigs.
joints , lower , mph , pull , wheel
Anybody want to trade my Sport front brakes for your SR5 front brakes? Reh0055 4th Gen T4Rs 2 07-29-2018 09:24 AM
Front end loose geenowalker 4th Gen T4Rs 9 11-05-2016 10:06 PM
Something loose in the front end judoant 3rd gen T4Rs 11 11-15-2011 04:23 PM
Loose Front End? Fortini01 Problems & Warranty Issues 1 03-15-2006 09:55 PM
Pulsate Brakes on my 03 4 runner sr5 & Seat loose... dutzit1 Problems & Warranty Issues 1 12-12-2003 04:39 PM
