Old 09-15-2020, 05:19 PM #1
Hokie-Pokie VT's Avatar
Hokie-Pokie VT Hokie-Pokie VT is offline
Hokie-Pokie VT is on a distinguished road
What happened to my brake pads?
So a few weeks ago I did the Upper and Lower Ball joints on my 4R, which involved removing the brake calipers. On the driver side we actually took the calipers/pads apart to get them off, so they had to be put back together. Fast forward 2 weeks, and my brakes are squeaking only on the driver side. Take the wheel off to check the pads and this is what I find. The pads are cracking/breaking apart in large pieces on the edges. Also the pad on the outer side (closer to the wheel) is significantly smaller and more worn than the pad on the inside (closer to the engine). See my images below.
InkedIMG_20200913_120556_LI
InkedIMG_20200913_120609_LI
Stuck pin? Do I also need new calipers? They are stock and have 225k on them so it wouldn't be surprising. It looks to me like they are touching the rotor in the second picture.
Thanks all!
2002 4Runner SR5 4WD
Hokie-Pokie VT is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 06:31 PM #2
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
Have you noticed a decrease in MPG or a need to give it a little more foot to get going?
Looks like stuck calipers. I've never seen pads break apart like that other than in racing. Extreme heat would do that. I supposed a stuck caliper could cause it.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 06:42 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I would agree the calipers are stuck. Can you spin the rotor by hand? If you take a short drive is the heat rolling off that pad areas through the rim. They can stick at any time.
Old 09-15-2020, 07:16 PM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
If the pistons aren’t leaking or stuck, then just clean the calipers up and use new pads and hardware. Use appropriate lube such as silicone grease for the pins, pad ears and the back of the pads.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 08:15 PM #5
Definitely have not noticed any decrease in brake effectiveness, however I have had some issues with acceleration lately, but they feel more like drivetrain (I think the Torque Converter is bad). Definitely no leaks in brake fluid or abnormal sponginess in the pedal, so I think the pressure in the system is still good.
Thank you all for your input. I have to have a shop do the pads because I just don't have time, but Ill let them know to clean them off well and apply grease to the pins. New pads will be coming from Amazon, I went with higher end GreenStuff pads this go around. Hopefully wont produce as much dust. These pads were AutoZone Golds.
Thanks again!
Old 09-16-2020, 09:35 AM #6
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Thanks all!
Also in on a stuck caliper. Can you spin the tire? Should be able to get at least a revolution or more with a hard spin. I've had several dragging calipers, a couple recently rebuilt, start dragging. Classic sign is more wear on the inner pad.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 09-16-2020, 11:49 AM #7
Yeah Ill see what the shop says, but in my case the pad with significantly more wear is the outer pad. Unfortunately, I cant even easily jack it up to give the tire a spin, my apartment parking lot is too tight.
closer , driver , pad , pads , side
anyone ever mess up a brake booster by changing brake pads? jluu6r 3rd gen T4Rs 19 12-12-2019 05:01 PM
Tundra Brake Upgrade: Brake Pads Side Specific? trevo_man 3rd gen T4Rs 3 10-05-2016 11:45 PM
Tundra brake caliper leaked brake fluid all over pads, replace or clean pads? Srt4runner 3rd gen T4Rs 8 10-30-2015 12:42 AM
brake pads. my brake pads r squeeling. want to know if Thermo quiet will work spartacus 3rd gen T4Rs 4 04-21-2012 08:00 AM
