05-08-2021, 10:41 PM
Real Name: Devan
Real Name: Devan
Coolant Overflow Relocation Options
In the final stretch of fitting my winch and currently trying to hook up my AGM batt, only thing is the damn coolant overflow bottle is in the way. I picked up a 34/78 battery so I can use the side terminals to run a direct line to my winch, however the bottle ironically sits directly in front of the 2nd positive terminal, with only about an inch or so to spare. I was wondering if there's a trick I'm unaware of in regards to moving the OEM bottle to a new position (perhaps by making a new bracket of sorts), or if it would be recommended to just snag a skinny aftermarket tank? If the latter I saw some people on yota-tech suggest Moroso or Mr. Gasket, however I'm not sure which ones will fit so any advice would be appreciated; I rarely trust """universal""" mounts as they never seem to work as well as promised, if they work at all. This seems to be a common problem for folks running dual batts, so I have a feeling theres a simple solution I just haven't come across yet
Also been toying with the idea of welding up my own since they're so simple, would be nice to hear if anyone else has done so as well
05-10-2021, 12:05 AM
Real Name: Leif
Real Name: Leif
i've seen a lot of room for the bottle open up if you delete the OEM airbox and resonator and drop in a K&N or similar. i know that doesn't solve the bracket problem, but it could be a start. i thought i saw someone's rig with dual batts up front a couple weeks ago but i'm forgetting whose it was.
@ habanero
didn't you double your battery fun and move your overflow? your buildup thread on YT is just epic long, but i think i finally found one shot of your dual batts.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
05-10-2021, 07:06 AM
Real Name: Throws like a girl
Good memory
@ photoleif
Originally I stuck a bike bottle cage to the air box with a bottle w/modified lid. Close, but not quite big enough.
So next I stuck the original coolant overflow tank in the same place. There was just enough room above the power steering reservoir to make it work. I've been running it like this for almost 5 years now.
If you've got a single battery you may be able to come up with something that will fit in the space between the battery, fan shroud, and alternator...perhaps something around the charcoal canister even. If automatic what about the space in the corner next to the master cylinder, where my clutch fluid reservoir sits? IIRC that's an emptyish area for auto trans, if it doesn't sit too high...
for more pics...
My set-up for my 96 3.4 manual trans...
post 2879 habanero's 1996 4Runner Build-Up Thread - Page 144 - YotaTech Forums
post 3595 habanero's 1996 4Runner Build-Up Thread - Page 180 - YotaTech Forums
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
05-10-2021, 08:38 AM
Real Name: keith and jenny
I went to autozone, oem bottle in hand, and picked up one slightly smaller. I don't remember what it is supposed to be for though. I mounted it exactly where
@ habenero
's is, side of the airbox. I made a little bracket out of 1/8" steel that the bottle slides right on to. Been about 3 years with no problems.
I almost relocated the OEM one to that spot, but all the clearances were just a little tight for my liking. Obviously
@ habanero
hasn't had an issue with it though.
05-10-2021, 08:47 AM
@ habanero
It's true, I had to be pretty precise to clear the p/s reservoir enough to account both reservoir and engine movement.
Also keep in mind where in the air box you add hardware, if you attach a bracket or overflow to it, that they are in front of and don't interfere with the air filter.
05-10-2021, 09:48 AM
Real Name: Leif
Real Name: Leif
Originally Posted by habanero
post 3595
rofl see? epic long :-) and thanks for chiming in. did you DIY a bracket for the OEM overflow reservoir?
edit: whoop, sorry. i see in a much-later post (#3326 whew...) that you bolted it to the airbox with some silicone to seal. has that been solid and workable for you?
05-10-2021, 11:16 AM
official vendor
official vendor
05-10-2021, 02:15 PM
Real Name: Devan
Real Name: Devan
Good memory
@ photoleif
for more pics...
I was thinking of moving it right here but it's a little too tight for me, would rather keep it fairly tucked away. I've been eyeing one of those cylinder types since they take up no space at all, but how it'll mount is still a gamble
Originally Posted by MStudt
That's for the washer fluid reservoir and is also sold out
05-10-2021, 03:46 PM
Heh, it is kind of a little bit long, isn't it? More than a decade of documenting itchy fingers and a curious mind. If it helps any there's a table of contents with links (that I need to update for the latest stuff) on post 2.
I did use 2 bolts to mount the reservoir. It was a little hard to get them started from inside the bottle because the holes are pretty tight. I wanted the silicone to have less chance to vibrate loose and leak. So far it's worked great.
I wanted to bolt the original bracket to the air box to slide the reservoir on but there simply wasn't enough room, the bottle is bolted in with the smooth side towards the box so the curve on the, urm, curvy side, accommodates the p/s reservoir.
If the bike bottle had been bigger (was using the larger typical bottle) that would have been awesome because goofy stuff cracks me up- and I'm a cyclist so it'd be like a touch of home.
05-10-2021, 04:17 PM
Real Name: Leif
Real Name: Leif
the water bottle mod did make me laugh, but what nearly made me spit toothpaste all over was the 'porcupine' clamping on your visors. dunno why but that really got me.
i'm not planning on doing this to my baby (the 4R), but the truck might just get the second battery up front so i have half a chance of taking off the topper and sleeping platform now and then. thanks for the tips on some options.
05-15-2021, 10:11 PM
Real Name: Devan
Real Name: Devan
Well, I tried to use a 1L bottle from Moroso and attach it to where the old bottle sat. Fit great, looked great, was easy as hell to install... except for the part is was way too small - apparently when Toyota says their bottle are 1L capacity, they're talking about the fill line and really mean the bottle is just under 2L to the brim, and needless to say the Moroso bottle is 1L to the brim Time for a bigger one I guess
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
