Old 09-16-2020, 09:08 PM #1
MarkBlack's Avatar
MarkBlack MarkBlack is offline
Real Name: 1997 4RUNNER
MarkBlack is on a distinguished road
MarkBlack's Avatar
Splicing wires to swap door from 99 to 97
So my aunt messed my door up on my 1997 SR5. I went to the salvage yard and grabbed a new door from a 1999 limited Not thinking about the wiring harness. So my question is, is it possible to splice the wires and change the wiring harness? Or should I just wait for a 1997 to pop up.
Splicing wires to swap door from 99 to 97-109f9270-a0cf-4b08-94fc-da776ab4b534-jpg
MarkBlack is offline   Reply With QuoteReply With Quote
Old 09-16-2020, 09:55 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You probably can splice it but your going to need both electrical wiring diagrams to match things up and verify circuits..
Old 09-17-2020, 08:35 AM #3
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Cant you just swap wiring harness between the two doors? Or is that a major PITA?
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 09:13 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If that is the case. you can swap the door harness and guts of each shell if need be. :-) I never studied the differences between the connectors nor the wiring. 1999 is the first year of the Communication bus. I do know they swap connectors on purpose when changed are made so people don't plug in incompatible wiring.
Old 09-17-2020, 11:24 AM #5
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
I actually did this just in reverse. I put a door from a 98 on my 2000. I was able to swap the harness and re-pin the window regulator connector. For me I lost the auto function of the window on my 2000. You may be in more luck putting the newer door on the older truck.
Swapping the harness is not very difficult and you can keep the lock and window actuator in the door.
1998 front door on a 2000
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 01:38 PM #6
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
I messed around with something similar when I wanted to add heated mirrors from a '99 to my '97. I bought the mirror at the junkyard, and the full door harness thinking I can just replace the '97 harness with the '99, and have the connector for the mirror heater.
No such luck - the two harnesses are completely different, as are the connectors that mate to the vehicle under the dash. You'll spend a lot of time trying to re-splice the '99 to work in the '97 vehicle.
Your best bet is probably to swap the entire harness from the old '97 door into the new '99 door. It may be a decent amount of work, so you may be better off trying to find a '97 door instead.
I only had to run one additional wire for the mirror heater, so I ran it in parallel to the main harness:
I didn't use the harness I got with the '99 mirror, I just took it apart to use as a source of wires:
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 01:48 PM #7
As others have said, you'll need to swap harnesses. The window, mirror and lock control is all different between the 96-98 and 99-01 4Runners. Not sure if the window motors will plug-n-play either (auto up/down was added in '99 for both front windows). Mechanically, they should be compatible, at least...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-18-2020, 03:18 AM #8
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Swapping all of the guts out isn't too hard. But a limited door should have the plastic cladding on the sides which your SR5 does not so it wouldn't match anyways.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 07:39 PM #9
MarkBlack's Avatar
MarkBlack's Avatar
Thanks for all the tips. I’m glad I didn’t start splicing. I got the idea from an old thread. But my wires didn’t match up to what was said in that post. I was able to swap the wiring harness. Not sure why I thought splicing would be easier 😂
Maybe it wasn’t a limited. It had leather so I just assumed it was a limited. The door matches up good! Just a little clear coat peeling but I can live with it
Old 09-19-2020, 11:15 AM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by MarkBlack View Post
Thanks for all the tips. I’m glad I didn’t start splicing. I got the idea from an old thread. But my wires didn’t match up to what was said in that post. I was able to swap the wiring harness. Not sure why I thought splicing would be easier Splicing wires to swap door from 99 to 97
Lots or sr5 had leather too
door , harness , question , wires , wiring
Door Ajar chime wires emsmatt 5th gen T4Rs 13 02-26-2020 11:19 PM
Extra rear door wires... Payara Offroad 5th gen T4Rs 5 12-30-2018 11:46 AM
Splicing new XM antenna on? Supermoney 3rd gen T4Rs 2 04-28-2015 06:48 PM
any one repair the wires where they go through door into kick panel ?? swerks Classic T4Rs 3 06-22-2014 07:53 AM
Door lock wires joe_coolish 3rd gen T4Rs 1 06-18-2008 01:51 PM
