Old 09-19-2020, 05:46 PM #1
nissanh nissanh is offline
Has anyone experience this crack before?
I saw this crack on rear left shock mounting plate.
The weld is intact however, the metal right below the weld is tearing apart. Must have been taking place for a long time.
Last Picture is from T4R member Scramble
Weld it? Any suggestions?
Thanks
Has anyone experience this crack before?-crack-1-jpg  Has anyone experience this crack before?-crack-view-2-jpg  Has anyone experience this crack before?-20200919_163049-jpg
Old 09-19-2020, 07:24 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I seen that area rotted out on a few of mine. Cracked so it has to be an extreme stress fracture that's going to need welded. You jump the 4 runner or do heavy off roading?
They are only welded on 3 sides with that crossmember tube weld being the weakest.
Old 09-19-2020, 07:53 PM #3
Not at all!
The weld at the tubular cross member is also has come loose. Dropping the gas tank is not too bad but love to avoid if I can.
How about weld the torn and run two high tensile nuts and bolts from the tubular cross member to shock-mount plate as shown below to avoid the requirement to drop the tank to weld that area?
Old 09-19-2020, 10:36 PM #4
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Maybe you added longer shocks but didn’t extend your bump stops?
If you do that then your shock bottoming out becomes the new bump stop.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 09-19-2020, 11:19 PM #5
good point
A very good point, but I installed these shocks about 2 years ago and never been off road for past 3 years. The 4R is used by my wife for past 3-4 years. It has air bags installed and I keep it at 7 psi. No issues to the passenger side.
Temporarily I put a ratchet strap to pull the plate towards the frame.
Could the Bilstein is too stiff? Those who installed this knows how pressurized these shock are.
Old 09-20-2020, 08:00 AM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ok. I just never seen that area crack nor that plate come loose on a non rusted one.
That plate wraps around the tube crossmember and welds on to it. I had one tube rot and the plate come loose as that cracked section was rotted away. Its only about 2 inch weld or less on that tube holding that plate to it.
Since it loose this makes more sense
Old 09-20-2020, 10:27 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I dont suspect too stiff as those plates have the cushion stops in the springs. Honestly I have no clue how this occueed on a non rusted. Not heavily off roaded 4 runner.
Old 09-20-2020, 11:50 AM #8
You don’t have to off-road to hit the bump stops on one of these 3rd gens with factory rear coils.
You put a good Costco run of groceries in the back and they will pretty well ride on the bump stops.
The drivers side has all the weight. It would be expected to fail first if something was going to fail.
What model rear shocks do you have?
Old 09-20-2020, 04:37 PM #9
The shocks are Bilstein 33187174. These were installed on January 2019 by me (miles driven 2800).
There is about 2 inches of (polished shaft) travel length to bottom out the shock. I do have air bags installed so 2 inches of down travel (body) is not possible to bottom out the shock.
Anyways, I am thinking of installing OEM Toyota rear shocks now. I don't want this to happen on the right side.
Just installed a 14 mm Bolt from the top of the plate where the crack originally started to the out side of the frame.
Has anyone experience this crack before?-untitled-jpg  Has anyone experience this crack before?-20200920_113604-jpg
Old 09-21-2020, 11:51 AM #10
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
What rear coils do you have paired with those bilsteins? The ones you listed, when used on 3rd gens, are for 3-4" rear lifts (890s, superflex, fzj80, 860s).
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 01:07 PM #11
Are you sure that isn't 100% normal? That plate may be top welded only from the factory.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-21-2020, 01:27 PM #12
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough turbo8 will become famous soon enough
turbo8's Avatar
Those shocks are for the next gen 4runner which are 2" longer compressed than the 3rd gen bilstein shocks. You would need to extend your bump stops to make these shocks work.
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 03:20 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That coil shock plate is welded on 3 sides. If the weld breaks or comes loose on the crossmember tube. It will work and destroy the frame Weld on the frame rail. Well this is what happens when they are rusty. As that inner frame rail is only about half as think as the c section of the rest of it. I seen this on Tetanus 1 [1998 SR5]
Old 09-21-2020, 05:31 PM #14
I use tall springs form a 99 and a spacer 1.5 above the coil. Guess the spring got sagged really bad. I have a good set of tall springs from another 99 (marks are green and red).Thinking of installing those with OEM shocks and without the spacer and air bags.
Can anyone confirm the Toyota 48531-80693 are Tokico's?
I might list the Bilsteins for sale soon.
Old 09-22-2020, 01:38 AM #15
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Yes. They are. Have a brand new pair waiting under my desk.
Be warned, they don’t come with all the accessories like aftermarket do. Look at the parts diagram carefully. That little baggy is all that come with the shock.
Has anyone experience this crack before?-b5823db3-3529-4c0e-9f2e-1a4999df112e-jpeg
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
crack , place , taking , time , weld
Crack fix TrexRunnerGirl 3rd gen T4Rs 15 12-28-2017 01:54 PM
How to tell if someone is smoking crack... StreetCreeper 3rd gen T4Rs 12 05-30-2017 03:01 AM
crack in windshield ulrich Problems & Warranty Issues 5 05-05-2015 07:21 AM
crack in tow hitch Franzmann 5th gen T4Rs 10 12-26-2012 12:50 AM
