Old 09-20-2020, 12:01 AM #1
sirhcx's Avatar
sirhcx sirhcx is offline
sirhcx is on a distinguished road
sirhcx's Avatar
Confusion on Rotor Size
I got a good deal on Amazon for Brembo rotors and Akebono pads, spent a good chunk of the afternoon carefully taking things apart, and working the rust welds only to run into a major hurdle.
The Brembo rotors say they are for a 16" rim and measure around 12.5" in diameter but the old rotors I took off are about 11.5" in diameter, so I cant mount the caliper with the Brembos.
So what has me really confused is that my 01 SR5 came with 16" 3 spoke rims from the factory but for some reason uses the 15" rim's rotor and brake caliper?
Can someone help point me in the right direction on what's going on?
2001 Toyota 4Runner SR5 4X4
3.4L V6, 250,000+ Miles
Slowly getting upgrades while fighting the rust...
sirhcx is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 02:38 AM #2
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
yes, the 4WD rotors are 12.56" in diameter.
it's a chance for you to upgrade your brakes. You already have the rotors and pads. All you need are the 4WD calipers which have the stamp S13WM, iirc.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 09:43 AM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Its worth moving up to larger 12.5" rotors, mine stop on a dime, don't fade and don't overheat causing warping.
Look for angled vane rotors if you can find them, the vanes are designed to be angled to grab air and funnel thru to center for better cooling than straight, non-angled rotors. I found those in centric brand.
Old 09-20-2020, 11:12 AM #4
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
Does the 3rd gen disk brake upgrade consist of using T-100 or first gen Tundra rotors?
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 12:57 PM #5
sirhcx's Avatar
sirhcx's Avatar
That's truly bizarre as mine is 4WD but the rotors I took off are about 11.5" and I dont have the cash to buy new calipers and mounting hardware.
I wonder if there was a factory upgrade for the larger rims but the hardware underneath stayed the same for a 15".
Old 09-21-2020, 10:46 AM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Tundra rotors and matching calipers
Old 09-21-2020, 01:14 PM #7
Not all 4WD's got 16" wheels.
He likely has a 15" wheel truck, despite having 16" wheels on there now with 4WD (previous owner upgrade).
Rear wheel cylinders are also smaller on the 15" wheel trucks, so upgrade those at the same time to keep things balanced front and rear.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
brembo , diameter , good , rims , rotors
UCA Bolt Size Confusion mscot 5th gen T4Rs 1 06-13-2019 04:43 PM
Rotor size Gerdo 3rd gen T4Rs 14 07-29-2011 12:37 PM
sway bar bush size confusion WHORERUNNER 3rd gen T4Rs 6 07-21-2011 12:43 PM
Tire size confusion. ZachAttack 4th Gen T4Rs 5 07-12-2011 11:02 AM
Rotor size? wildcar 3rd gen T4Rs 3 01-25-2009 03:15 PM
