Originally Posted by blockhead
Yes it’s automatic climate control. Would you send a pic of yours if you have a moment please?
yes it's the cabin temp sensor(Room Temperature Sensor Toyota vernacular) for the auto climate control. if it's not plugged in correctly you will get full blast heat all the time.
The only reason I know this.... is because one time I forgot to plug it back in and I had full blast heat all the time.
this is the best I can do right now, it should be connected to the inside of the lower finish panel (the panel below the steering wheel) also has a 2 wire plug that should be super obvious... it's a pain because if you try to remove that lower panel it always gets in the way. I would take a picture but it's dark here and I'm 3 to 5 beers into it right now.
