Old 09-23-2020, 10:29 AM #1
BKyota BKyota is offline
BKyota is on a distinguished road
Front diff oil seal help
I’m replacing my front diff oil seal and when I removed the drivers side CV axle, this spring was dangling in the opening of the diff. Anyone know what this is? Part of the bad oil seal?
BKyota is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 10:42 AM #2
JCruz JCruz is offline
JCruz will become famous soon enough
Yup.
That goes inside the oil seal.
JCruz is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 02:41 PM #3
nissanh nissanh is offline
Install a new Oil seal. That spring stays in the oil seal. Make sure to use OEM OIL seals.
Old 09-23-2020, 05:09 PM #4
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Yes, that's part of the old bad seal.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 07:36 PM #5
Thanks everyone! New OEM oil seal is installed and so far no leaking. Seeing the spring dangling in the diff when I removed the axle was a bit of a curve ball. Huge thanks to Timmy the Toolmans YouTube tutorial on this repair which I watched several times to prepare.
Old 09-23-2020, 10:19 PM #6
Just an FYI: Never get rid of the OEM CV. Just reboot it. Aftermarket CV's are out of balance and ton of other failures.
Old 09-24-2020, 10:22 AM #7
Thanks for reaffirming my choices. This project all started when I was replacing my front shocks, while cutting out the frozen lower shock bolt on the drivers side I sliced the outer CV boot. The factory original CV’s were in perfect shape. After much research I decided to reboot just the one side and keep my stock axle. Followed Timmys super helpful CV reboot video. However, after successfully rebooting and reinstalling the axle I noticed a drip out of that same side of the diff. Luckily my local Toyota parts had one drivers side oils seal in stock. She’s all fixed up now, glad I salvaged my OEM axle.
Old 09-24-2020, 11:13 AM #8
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Great to hear our video helped you out. Good job tackling the job yourself. You saved yourself a ton of money.
dangling , diff , front , oil , seal
Front Diff: Replace Axle Seal? or Both Seal and CV? Berty_K 4th Gen T4Rs 10 10-10-2021 10:36 PM
Front diff axle seal leak...is it diff oil? DK327 3rd gen T4Rs 8 08-13-2018 03:31 PM
Front Diff Axle Seal Leak Unner 3rd gen T4Rs 34 08-27-2017 10:01 PM
How to:front diff oil seal replacement Mellemel 3rd gen T4Rs 7 05-17-2016 03:37 PM
cant get front diff (CV) oil seal to not leak...pls help on this cordrayj1 3rd gen T4Rs 7 08-18-2011 08:43 AM
