Old 09-23-2020, 01:25 PM #1
nissanh nissanh is offline
How many of you got this bracket?
Do you have this bracket in your 4runner? First time I am seeing this!
How many of you got this bracket?-untitled-jpg
Old 09-23-2020, 01:28 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I never seen one of those on the 6 that I have owned.
Old 09-23-2020, 02:26 PM #3
I have those two bolts at the bottom side of the top plate but wonder the purpose of it.
At some point Toyota decided to reinforce that plate! We now know why!
Old 09-23-2020, 09:38 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh. It needs reinforced. The pipe weld is the weakest point. That entire coil spring setup plate is not one of the best designs.
I wish they just would have made access plugs from above for the shock bolts. As that make shock changing a lot easier.
Just a design flaw. They happen.
Those bolts were probably plate alignment bolts for the frame jig when machines welded the frames together.
A pile of frame holes are only in the frame so machines and jigs can align the steel fast and machine weld the frames together as fast as the frame assembly line can do it.
Old 09-23-2020, 10:35 PM #5
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
How can anyone be sure that is for reinforcement?
Old 09-24-2020, 09:22 AM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nope. We cant. I haven't seen that bracket on any early years or late model. My 2001 dosent have it.
Old 09-24-2020, 10:06 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Also that bracket I have never seen in our parts diagram on frame parts. I dont think any other Toyota uses the same frame as our 3rd gen but I could be wrong.
Old 09-24-2020, 11:22 AM #8
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
I have never seen that bracket before, in likely 25+ runners ive been under in junkyards
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 11:23 AM #9
@eimkeith This may be a neat area to reinforce with some of your goodies!
Old 09-24-2020, 12:31 PM #10
I am currently dealing with a cracked-weld at top plate to tube-cross member (issue was the shock bottomed out and acted as a bump stop). I later found the entire plate is ripping from the frame and moving towards the passenger side (right side) see my other thread. Based on the shock orientation we can expect the force is towards the right side.
I wish that reinforcement bracket was there to prevent that lateral movement.
The image also shows a different routing of rear brake hose!
Old 09-24-2020, 01:13 PM #11
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Later models have 2 brake lines down to the rear axle for traction control.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 05:27 PM #12
T4R2014's Avatar
T4R2014's Avatar
2001 owners still do not have it. Can any 2002 owners take a look?
Old 09-24-2020, 06:53 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My 2001 has 2 rear brake lines and I almost certain I dont that bracket. I will double check. I would have seen it as I cleaned and painted the entire underneath of that rig. :/
Old 09-24-2020, 09:47 PM #14
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Neither my original '99 frame nor my replacement 2001 frame had it. And I am VERY familiar with those frames.
My Backyard Frame Swap
Old 09-25-2020, 12:41 PM #15
Later models also have the evap can in the rear.
Who knows what it’s for.
4runner , bracket , time
Need a new engine fan bracket bearing, bearing or whole bracket? Jon 3rd gen T4Rs 36 03-25-2019 01:22 PM
need help with bracket jvillar 4th Gen T4Rs 3 02-23-2014 02:26 AM
Fan bracket for 3.4l vipergrhd Want to Buy/Trade 2 10-30-2013 04:09 PM
What is this bracket for? MrGrimm 5th gen T4Rs 2 12-01-2010 09:19 PM
possible bracket VCV79 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-20-2007 12:07 AM
