Old 09-24-2020, 05:43 PM #16
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Originally Posted by phattyduck View Post
Here is the above instructions in image form that should work on the '96-'00 4Runners:
And yes, getting the bench bleed on the master correct is necessary. It has a balance system in it that is required to get the front discs and rear drums to play nicely together.
You may also have some air in the ABS system that needs to be removed.
I'm in the middle of a brake bleeding saga myself. My brakes are back to about 80% of where they should be after a new master cylinder and Tundra front brakes. Need to re-bleed to get some air out of the ABS system at the moment.
Where is the lsp and bv? (Last step on the page)
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 07:25 PM #17
Originally Posted by 19963.4lsr5 View Post
Do you have a pressure bleeder?
Vacuum bleeder, though I have speed bleeders on the 4Runner now.
The LSP is on the rear of non-ABS 4Runners only. Not sure what BV refers to (probably part of the same non-ABS brake system).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-25-2020, 01:13 AM #18
Arv Arv is offline
Arv is on a distinguished road
Arv Arv is offline
Looks like all the key points have been mentioned including making sure the rear brakes are adjusted and purging the air in the ABS (if any).
Just did the 199 TBU, front SS and rear hose, and rear axle seals so I had to disconnect the rear cylinders. I had to bleed 3 times to get the "early" bite that one would expect with new brakes, even after the 2nd round the "travel" was long.
IMHO 2 man bleeding beats any of those one man systems! But I'm sure others will say their vac or gadget works better.
Last thing to tackle is to replace my rear drums, Les Sw tech messed up the turning so I'm looking for new drums.
Arv is offline   Reply With QuoteReply With Quote
bleeding , brake , brakes , front , rear
Bleeding Brakes Samm25 4th Gen T4Rs 5 06-09-2018 10:53 PM
Tip for bleeding brakes (4th & 5th gen) Jed Maintenance/Detailing 9 04-08-2017 05:37 PM
bleeding brakes Louie Maintenance/Detailing 33 02-27-2016 12:18 AM
Bleeding my brakes oa8888 Maintenance/Detailing 5 12-21-2009 08:15 PM
Bleeding brakes sciff5 4th Gen T4Rs 1 03-14-2009 06:46 PM
