Old 09-23-2020, 08:09 PM #1
hntz4x4 hntz4x4 is offline
hntz4x4 will become famous soon enough
Lowering front diff
The front diff on my 96 is leaking. It appears to be coming out the top of the diff. I am not sure if the breather tube is messed up or something? Can I unbolt the bolts that hold the front diff in place and lower it some to inspect without removing the cv axles?
Thanks,
Ryan
hntz4x4 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 01:38 PM #2
If it is leaking from the top, first check the breather line. You should be able to see it, if not reach it from below and behind the diff.
It comes out at the top, visible in the above pick just to the right of the differential ring gear.
edit: Also make sure it isn't engine oil, leaked from the filter during an oil change...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-24-2020, 08:18 PM #3
Quite certain its gear oil. I can see the breather but can't my hand in there to feel if loose or broken.
Old 09-26-2020, 01:28 PM #4
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
That's how people put in spacers from Total Chaos and the like. Put a floor jack underneath for support, undo the 2 bolts and drop it slightly. Don't expect tons of droop but should give you a little extra wiggle room. Might help to have weight off wheels
Old 09-27-2020, 06:38 PM #5
From the looks of it, it looked like the soft line at the nipple failed(?). There was gear oil seeping out from that point. It was a huge pain in the butt without pulling the whole diff, but with the help of my son and some really long bent tip pliers we were able to slip a piece of about 3' long 5/16ths fuel line on the nipple. Just bypassed the soft/hard line combo that was factory, and added a new breather. Took it out for a spin, does not appear to be leaking anymore.
diff , front , lowering , place , unbolt
Front diff gear ratio verification - diff removed and no vehicle info SDmtnbkr 3rd gen T4Rs 6 07-26-2017 09:39 PM
Lowering Rear Instead of Raising Front in Order to Level luke87gt 4th Gen T4Rs 16 07-29-2015 10:27 PM
Lowering the rear instead of lifting the front!! kipseverino 5th gen T4Rs 2 05-06-2011 12:04 AM
lowering rear end? instead of lifting front? Trevloc 4th Gen T4Rs 14 01-06-2011 09:59 PM
Lowering '94 front suspension Jake4R Classic T4Rs 4 08-24-2010 09:59 PM
