Old 09-27-2020, 02:08 AM #16
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
I just replaced my tps as well actually cause I got a p0120 code on the last camping trip I went on.. Just went on a test drive, I used to have a slight hesitation/felt like it was going to stall occasionally after coming out of a stop but now it seems like it’s gone. Hoping it stays that way.. Curious to see if it fixes your problem.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 04:03 AM #17
Originally Posted by gamefreakgc View Post
Thank you once again Tim! I only have the free online one for the 2002 so it didn't have the full testing procedure since the TPS changed. Turns out VC-E2 is out of spec under vacuum and has a reading of 7.9K ohms. Max is 5.9K ohms. New TPS it is.
The tps has a vacuum port?
Old 09-27-2020, 05:33 AM #18
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Originally Posted by 19963.4lsr5 View Post
The tps has a vacuum port? .........
TPS does not have a vacuum port, pre 01 TB's had port on cable side of TB, look closely at pic Tim posted shows port labled vacuum with arrow.
Old 09-27-2020, 06:44 AM #19
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Could be a bad fuel injector, bad spark plugs, bad coil. What cylinder? Swap the coil on the bad cylinder and see if the issue migrates to test the coils.
My 2005 SR5 with 150,000 miles has never had a miss or CEL. No offroading.
My evaporator coil just failed. Second time. The first time was in 2009 when the dealer replaced one. I paid $800 for that job. You have to take down the dash to get to the evaporator. Big job. labor-intensive.
Captsolo is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 06:51 AM #20
Real Name: Mark
Real Name: Mark
My 01 has had a quirk for a bit that I think is TPS related, dead/hesitation spot, leaving stop at 2-3 shift point speed.
Been waiting to see if code would set, going by posted you don't always get a code. Hhmm, wonder what set's the code.
@gamefreakgc , good thinkin with Vac. On the bright side not a problem finding 3 wire TPS not so with 4-wire year ago 1 place had them, guess it time to put it on.
Old 09-27-2020, 06:59 AM #21
Real Name: Mark
Real Name: Mark
Originally Posted by Captsolo View Post
You have to take down the dash to get to the evaporator...
Lotta things on 4th Gen harder to get at, 3rd Gen not bad.
Old 09-27-2020, 09:08 AM #22
T4topher's Avatar
T4topher's Avatar
This is exactly what I had pretty much and as far as I can tell on my little test drive yesterday it seemed like it was gone. Just replaced the tps.
Old 09-27-2020, 03:48 PM #23
Real Name: Mark
Real Name: Mark
Mine doesn't act up every time I drive it or very often.
Old 09-27-2020, 06:35 PM #24
T4topher's Avatar
T4topher's Avatar
Neither did mine, it was only every once and a while.
Old 09-27-2020, 11:09 PM #25
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Fixing the hoses and adding the fuel stabilizers helped but still idling low. 550 or lower sometimes when coming to a stop (feels like it's about to stall) and 675 in park. New TPS is still on order.
326WHP 347TQ
Old 09-30-2020, 10:21 PM #26
Real Name: Jerod
Real Name: Jerod
New TPS is in and runs even better, pretty much back to normal. I think in time the idle speed will level out even more.
So to recap, the #1 offender was indeed the TPS however it wasn't the sole cause. I confirmed it was failing slowly with the resistance test but I noticed in one of my dyno logs a few months ago the throttle position on my AEC said the throttle was at 103%. This should have been a red flag since it can't open more than 100%. I calibrated it about 3 years ago so since then the TPS voltage has degraded over time.
Replacing the IAC valve also helped the idle speed though it still threatened to stall a few times, though not as bad as before.
For extra measure, I did adjust the throttle stop screw. It's behind the spring on the bottom on the front facing side of the throttle body. I did one complete turn. For reference, there was 7 threads showing on the paint side so I turned it once to 6 threads.
EDIT: So don't mess with the throttle stop screw LOL. Idled at like 2000 RPMs! I put it back to where it was before and it's better now.
326WHP 347TQ
idle , idles , place , stalling , trims
00 4runner Stalling at idle tpham18nm 3rd gen T4Rs 15 03-17-2017 07:39 PM
idle and stalling issues holen01 3rd gen T4Rs 6 10-16-2014 03:51 PM
1998 stalling while idle Mattepling 3rd gen T4Rs 2 10-10-2014 12:29 PM
Stalling at Idle w/ No Load HedgehogOutdoors Maintenance/Detailing 4 02-08-2013 10:21 AM
Stalling out, won't idle dkovac 3rd gen T4Rs 1 06-16-2009 08:47 AM
