Old 09-28-2020, 08:01 PM #1
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Replaced LBJs - now squeaking?
Has anybody hear noticed a squeak/creak develop after changing out their ball joints? Yesterday I finally ditched the 20 year old LBJs for some brand new ones, and about halfway to work today I developed a squeaking coming from the passenger side triggered by 90% of bumps in the road, at practically all speeds. Doesn't seem impacted by anything, at least not that I can tell (turning, 4WD, etc.)
I followed Timmy's tutorial by the book, which doesn't exactly require disconnecting much to do the job but nevertheless I went back through and re-torqued everything down with no luck. I don't exactly see why it would be the ball joint as they typically only squeak once they've gone dry, but at the same time it's the only thing I worked on this weekend so I don't see why it wouldn't be either. Maybe because of no alignment yet? You can practically match the squeak to the bouncing/shock absorption of the vehicle
Anybody been through a similar situation? I'm wondering if maybe it's the LCA itself, somehow - but some advice would be appreciated before taking a shotgun approach! Did the ball joints on Sunday and had a quiet ride on Saturday.
Old 09-28-2020, 09:14 PM #2
OpenYota's Avatar
OpenYota OpenYota is offline
OpenYota is on a distinguished road
OpenYota's Avatar
How are your sway bar bushings looking?
Mine started to squeak pretty bad after I changed my ball joints but they were shot
2001 SR5 4WD
OpenYota is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 10:09 PM #3
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
All brand new. Already chased those noises a week or two ago! I actually undid and retightened the end links thinking maybe their bushing were squeaking, might do the bar now that you mention it
Old 09-29-2020, 02:01 AM #4
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
What brand ball joints? Did you check them for grease before install?
Not sure what you undid, but if you undid any of the controll arm bolts, did you torque/tighten them when the rig was supporting its own weight on the tires?
Correct ball joint on the correct side?
Never had any squeaks after such work, so just guessing.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 04:09 AM #5
I bought my rig with new lower ball joints installed from the previous owner.
They were grease able and he never greased them. I had the suspension creek sound. Spun in some grease zercs and cranked them full and noise went away.
Old 09-29-2020, 05:28 AM #6
Limoncho Limoncho is offline
Limoncho is on a distinguished road
Interesting
Limoncho is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 08:29 AM #7
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
I see in your sig you have MStudt links. Maybe when you did the LBJ job, the bottom bolts somehow got loosened a smidge from all of the jarring around on the job? I only say that because those can be some very chattery front links if they're not installed super tight and greased up (heims)
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 07:36 PM #8
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Well interesting development, I set the LBJ castle nut at 110ft-lbs instead of the minimum 105, and now the squeaking is much less consistent. Seems to only happen around city speeds now, and somewhat less sensitive. Is it possible Toyota gave me a bad joint off the floor? Continuing to increase the torque until it stops doesn't seem like the greatest idea to me
Was trying to get a video to upload for reference, but I can never catch it happening
Brand new OEM set. Already full of grease.
Way ahead of you, was one of the first things I took off and retightened. Regard my second post
Old 09-30-2020, 08:39 PM #9
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Video
Got a clip
Old 10-03-2020, 06:27 PM #10
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Think I found it. Sprayed some silicone WD40 on the UCA bushings and the noise all but stopped, and slowly started to creep back as the lube dried/dripped off. Very strange and unlikely for them to go at the exact same time the LBJs were replaced, but I guess the proof is in the pudding
ball , joints , lbjs , squeaking , wondering
Replaced under warranty, what have you had repaired/replaced? WandaRunner 5th gen T4Rs 40 12-29-2018 08:07 PM
Replaced rear sway bar bushings, already squeaking 5 days later Supermoney 3rd gen T4Rs 10 04-26-2017 11:07 PM
When to Replace Recall/Toyota Replaced LBJs WeAreSLO 3rd gen T4Rs 12 01-25-2017 01:53 AM
replaced LBJs, UBJs, CV Axles, ITR and, OTR Predatorhouse 3rd gen T4Rs 0 09-16-2014 10:17 AM
To Those of You That Have Replaced Your LBJs xcmtb83 3rd gen T4Rs 20 11-09-2013 04:53 PM
