Old 09-30-2020, 01:42 PM #1
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Poly sway bar bushings binding up quickly
I've been using the Energy poly bushings for a few years but whenever I go to regrease them I find the front sway bar is usually binding badly and the little grease channels are full up of sand and grit. I think it's causing the problem I have with the tops of the front end links snapping off.
Is there some special grease or trick to try before I go back to Toyota rubber ones? I've tried the Energy Formula 5 grease, Silamaric (silicone dry film plastic safe brake grease), and a couple others, and tried Strongflex poly bushing graphite grease this time but havent checked on it yet. Is my sway bar slightly bent or what? Seems to be some sideways play in it that pushes all the grease out. That front ones seems very stout and hard to bend though.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 08:26 PM #2
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
I would go back to rubber. One less headache.
Old 10-01-2020, 09:48 AM #3
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
You could try some of the techniques used in this video: How to Fix Polyurethane Bushing Squeak Permanently - YouTube
Bad Luck is online now   Reply With QuoteReply With Quote
bar , front , grease , poly , sway
Poly sway bar bushings? Scharfschütze 5th gen T4Rs 90 04-26-2021 09:46 AM
Energy Poly Sway Bar Bushings Lasted 8 Months 07V8 4th Gen T4Rs 28 04-12-2016 05:34 PM
4th/3rd Gen Poly Sway-bar Bushings, Trim Packers, etc - VA montana_jeepn For Sale: T4R Items 7 04-05-2015 12:51 AM
Poly sway bushings, nothing but headache ! maxspeed96ct 3rd gen T4Rs 12 12-11-2011 04:07 PM
Poly Bushings for Sway Bar 004Gunner General Discussions 10 03-19-2010 11:14 PM
