Old 10-02-2020, 01:34 AM #16
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Draw lines from side to side across the retaining ring. Then install the axle and spin it a few times. Then pull it out and see where the rubber seal lip rubbed off the sharpie.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 10:03 AM #17
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Originally Posted by WrenchTech View Post
I examined the seal in the axle housing and indeed it does have an outer and inner lip. I can see now that if the outer lip was riding where my grease line indicated, the inner lip may have been riding too close to the edge of the machined surface.
This is interesting. Are you using OEM parts? The seals I got from Toyota only had one lip while the ones I took off clearly had an inner and outer lip.
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 09:14 PM #18
WrenchTech's Avatar
WrenchTech WrenchTech is offline
Real Name: Matt S.
WrenchTech is on a distinguished road
WrenchTech's Avatar
Real Name: Matt S.
I should have grabbed a picture of it. I got my kit from Marlin Crawler. It is all supposed to be OEM stuff. Mine was kind of a thick seal with two distinct ridges that I took to be the lips. Well they were a little more than ridges, but they were connected by a U-shaped trough between themThat separated them buy a little more than an eighth of an inch, not distinctly separate.
1999 SR5 3.4 auto, Horizon Blue Metalic 8N1, blue cloth, steel Daytona wheels, 265/75/16 AT tires, rear heat, A/C, sunroof, electric locking rear dif.
WrenchTech is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 09:19 PM #19
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Here a thread I posted for my old FJC. Toyota did the same dumbass move on this truck as well.
Rear Axle leak & bearing replacement | Toyota FJ Cruiser Forum
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 09:23 PM #20
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
Ok, this is what I got when I moved the ABS gear and the lock ring up so that I had about 6 mm of the machined surface showing. I tried 4 mm and found that the dust seal was running off the bottom edge of the lock ring. When I moved it to 6 mm I got this result, which I think shows the seal riding fairly close to the middle and the dust seal running just inside the lower edge. Ignore the sharpie line on the left and look at the one on the right. The dust seal mark is very faint. Also, ignore all the dust. I’m not sure where it came from, but I cleaned it up.
And for what it's worth, the lock ring is not a Toyota part. I got it at my local NAPA. If you ask for one, chances are pretty good they will say they don't carry a lock ring for this application. If you know the part # though, they can get it for you. I paid about $13. part # 27BL0312
Old 10-02-2020, 10:46 PM #21
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
I’m going to preface this my saying it’s been several years since I did this repair so it’s not as clear as it could be in memory.
I find your description of the seal to be a little funny, and the witness marks too. I’m suspecting that you have installed an old style seal and that’s why your measurements don’t jive. If you take a look on page 6 of dr coffee’s thread Tim has posted a photo of old style vs new.
Does the photo help? Can you tell which you got?
Looking at marlins page for the kit they are careful to say Toyota oem on some parts but they say stock for the seal which is a little odd.
I could be way off and if so, ignore this.
Either way, looks like you are making progress. Good job.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 10:55 PM #22
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
I love how good pictures are with the newer smartphones. They are at least as good as my Canon DSLR from 10 years ago. Here is one of the stack as I was pressing the bearing and it's retaining ring. It's not my first choice. I would have liked to have supported the bearing more fully, but I tested it and the resistance on the outer surface of the bearing where it was engaging the bearing pocket was minimal. I got several pieces of steel like the one at the top of this stack for $1.50 each at my local recycling center, where I go to find all kinds of deals on steel. They recycle a lot of industrial stuff and agricultural machines, so the stuff I find is just mind-boggling. I see stuff I want every time I go there, but I would need a forklift to move a lot of it. The owners are kind enough to let me browse through what they have anytime I ask.
Old 10-02-2020, 11:12 PM #23
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
Here is how I pulled the ABS wheel and the lock ring back up after I had pressed them on too far.
I really like doing it with the splitter/puller, as opposed to using Dwayne's puller plate, because I can see where the lock ring is at any moment, with Dwayne's tool I can't see lock ring position at all. That said, Dwayne's tool it's great for simply pulling the ABS wheel off.
Old 10-02-2020, 11:42 PM #24
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
The seal I just got from Marlin has lips like the one on the right, the one Dr. says is the old style. Except the body of mine is not metal, or at least not bare metal. Mine looks like plastic. Being like the old style might explain my witness marks, and I may have misinterpreted what I see down by the lower shoulder that I was thinking is from a seal lip, which may not be. In any case, I think my seal is in a good spot.
Old 07-08-2021, 02:20 AM #25
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
Well it is something like nine months later and now I am working on an oil leak from the rusty back cover of my rear axle housing. One thing that seems pretty certain though, is that there’s no oil leaking from the lock rings and seals I installed last fall. Now I’m pulling out the whole axle housing to get it ready to have a new back cover welded on.This will give me a chance to install new sway bar links, shocks, springs and maybe go over to disk brakes.
abs , axle , job , press , work
Rear Axle Seals & Bearings psea17 3rd gen T4Rs 49 03-17-2022 10:17 PM
Rear axle seals, bearings, and brakes NegroTundra 3rd gen T4Rs 50 06-30-2018 11:31 PM
Leaky rear axle bearings/seals? 2ndhandyotaman 4th Gen T4Rs 1 11-27-2017 01:57 PM
Cost to replace rear axle bearings..... DENTFXR 4th Gen T4Rs 10 02-05-2013 03:18 PM
What is this? & Do I Need New Bearings? (Rear Axle) tbst 3rd gen T4Rs 7 01-23-2012 10:49 PM
