Old 10-02-2020, 01:17 AM #1
benjamin247's Avatar
benjamin247 benjamin247 is offline
benjamin247 is on a distinguished road
Is alignment needed after panhard correction?
I have the eimkeith panhard correction kit installed. It drives straight but, although the stability is noticeably better, it’s still not as stable before my 3” lift.
Should I get an alignment after PCK installation? I had an alignment don’t after my lift was installed.
1999 Black SR5 5-speed 4WD Rear e-locker
Suspension: Toytec 3" Ultimate Lift, JBA STD High Caster Upper A-arms, Eimkieth PCK
Wheels/Tires: Method 305 NV Bronze (16x8 | 0/4.5"), Goodyear Duratracs 285/75-16, 1.25" Spidertrax Wheel Spacers
Others: SRQ Fabrications Flush Grille, TJM T17 Front Bumper, Magnuson Supercharger, URD 7th Injector, Rock Gray Avery vinyl wrap, TG Sliders
benjamin247 is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 02:37 AM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
No, an alignment isn't necessary after the PCK because it's changing nothing with the front end where all the alignment adjustments happen with the Lower Control Arms and Outer Tie Rods.
A lift changes the handling characteristics of the rig. It's never going to feel as stable as it was stock. You're going to have to get use to the way it now drives or get rid of the lift.
Old 10-02-2020, 12:46 PM #3
phattyduck phattyduck is online now
Post the alignment printout... they may have done a half-assed job (or not been able to get the specs right due to the 3" lift).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 10-02-2020, 01:23 PM #4
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Actually since they do a "4 wheel alignment" and use the back wheels as reference, yes you should get it aligned again., are your front lower control arm adjusting cams in a similar position from side to side or are they compensating for the old position of the pan hard bar, also the tie rods are suppose to show the same amount of threads within 1.5mm. The truck will dog one way without the PCK and a 3"+ lift, once you centre the axle again it would change the alignment specs requiring some fine tuning to align it again.
My PCK is in the mail, my front LCA cams are slightly off from side to side, tie rods are within spec, alignment within spec after 2nd attempt and providing the toyota dealer the FSM.., and i'll be going back after the PCK install.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 10-04-2020, 08:27 PM #5
Devbot's Avatar
Devbot Devbot is online now
Real Name: Devan
Devbot's Avatar
Real Name: Devan
You should be getting an alignment after a lift regardless.
The truck won't feel as stable because you've raised the COG, which is already fairly high on SUVs. Eventually you learn to live with it and learn it's much, much more stable than it initially feels.
Devbot is online now   Reply With QuoteReply With Quote
alignment , correction , installed , lift , panhard
FS: eimkeith PCK® (Panhard Correction Kits) for 3rd gen $93.50, 4th/5th Gen $98.20 eimkeith For Sale: Suspension/Wheels/Tires 357 06-03-2022 03:52 PM
Panhard Correction Kits for the 4th gen - fix that panhard bar angle! eimkeith 4th Gen T4Rs 109 01-08-2021 04:21 PM
Panhard bar correction BikeDestroyer 3rd gen T4Rs 16 07-26-2020 08:07 PM
Panhard Correction Kit install - Shout Out to @eimkeith DaMonkey 3rd gen T4Rs 4 07-18-2018 12:29 AM
Panhard correction kit install Dezerts10 3rd gen T4Rs 22 05-24-2018 08:59 PM
