Old 10-02-2020, 07:50 PM #1
thobry's Avatar
thobry thobry is offline
thobry is on a distinguished road
thobry's Avatar
What tube is this: rear differential
I just replaced my rear shocks and springs. While doing that work I seemingly bumped what looks like some kind of “breather tube” which I wasn’t sure if it came loose or is supposed to be just like this : not connected to anything. I can’t tell if it need to be reconnected.
Does anyone know for sure if this is supposed to connect to something?
thobry is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 08:09 PM #2
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Pretty sure that’s the elocker breather.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 08:23 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Could also be the sunroof drain hose, I don't have a sunroof so don't know where they all go. There's 4. Easy way to find that one out though, just dump water on the sunroof.
326WHP 347TQ
Old 10-02-2020, 08:34 PM #4
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Looks pretty aftermarket to me, as does the red one in the background. My money is on airbags either in currently or were in at one time.
Possibly an aftermarket rear diff breather set up if the PO was a keener.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 08:52 PM #5
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Looks like the rear diff locker breather hose. Supposed to be slid in between the body floor brace and the body floor and held in by a little metal clip.
If you look at the body floor above the locker you should see the clip on the floor brace in one of the floor channels.
The hose will slide right back into place.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 09:06 PM #6
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
Dump water is great idea for finding the rear tubes....
Sunroof drain tubes= front two can be found in cavities behind the front kick panels and drain into the sills, rear two- left drains out the vent and right tube passes through a grommet in the body- both can be found behind the rear cargo panels and farther back from but near the wheel wells. They are approx 3/4" (but think metric) or so and clear plastic.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 11:21 PM #7
_Moose _Moose is offline
Real Name: Hah, good one!
_Moose is on a distinguished road
You didn't know, that's where Toyota dispenses it's Tang!
_Moose is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 11:45 PM #8
Just looked on my rig and the clip is just outboard of the fuel filler hose. Kind of hidden by the filler hose metal section.
I’m under there installing 10” Firestone air bags into my 890’s. Fun stuff.
Old 10-04-2020, 03:00 PM #9
thobry's Avatar
thobry's Avatar
Well I just fed the tube through this bracket holding the fuel tube.
At least it’s not dangling around now.
connect , connected , loose , rear , supposed
Center differential + rear differential + front differential = confusion! badburro 5th gen T4Rs 37 01-29-2019 12:40 PM
Rear differential rust and rear wheel axle starting to leak Boognish_Forever 3rd gen T4Rs 14 12-03-2018 04:38 PM
Differential vacuum tube. only two left in the country Philbush1127 3rd gen T4Rs 12 11-07-2015 10:35 PM
Help on a rear tube bumper MattJakobs 3rd gen T4Rs 32 09-26-2014 09:28 PM
Rear end vent tube txrunner06 4th Gen T4Rs 3 04-03-2014 06:51 PM
